Old 15th December 2010, 04:41 PM   #1
MiiB is offline MiiB  Denmark
Default Output buffers
Hello....
would like to explore the differnt topologies for output buffers that per example can be driven with a tube voltage stage...
I know of the types consisting of simple mosfet follower driven in Class a or a/b....but the types are typically without feecback and based on mosfets....
The one i have in mind.....must have...
gain of 1
high damping factor
scalable
high input z (easy load)
Btj output devices
anyone with a suitable concept...???
Old 15th December 2010, 04:53 PM   #2
Have you seen the JISBOS (unity gain), or the later version α20 / Alpha20 that has gain?
JISBOS - overview
The α20 Line Stage Amplifier
These have been used as buffers for tubed voltage-gain circuits, e.g. in the SOHA: The SOHA Headphone Amplifier
Old 15th December 2010, 05:16 PM   #3
StevenOH's Avatar
You can explore several ideas here:
New Class A, Super-A, Non-Switching : need a revival ?
Still another way to do SRPP power buffer is attached.
The truth is out there. Who can handle the truth?
Old 15th December 2010, 05:43 PM   #4
JISBOS - overview...
looks really interesting....and can be scaled to high power by inserting a cascode to shield the j-fets...maybe second stage with lateral mosfets driving the BTJ's.....
But...for higher power there must be some gain...else what happens when a large signal of maybe 30V is fed to the input J-fets...??
Old 15th December 2010, 05:48 PM   #5
I'm glad it might be useful to you! (Did you check the Alpha20? It's basically the same, except it has added gain - perhaps AMB & co. have implemented the same ideas.) At any rate, I can recommend talking a bit to AMB and Steinchen (owner of the DiamondStar JISBOS page). Very good people.
Old 15th December 2010, 05:56 PM   #6
It has added gain due to a resistor network in the feedback....
But as far as i see it.. for unity gain it has limited voltagesving due to the voltage capability of the input fets...but as the whole center of the fets is pulled up/down.. I may be wrong. Guess some simulation will show...
Old 15th December 2010, 08:32 PM   #7
nigelwright7557's Avatar
Hello....
I designed a similar amplifier with an SRPP front end driving into a class AB MOSFET amplifier. The only change I made to the AB amp was to reduce its gain to counteract the gain in the valve stage.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 15th December 2010, 09:29 PM   #8
ontoaba is offline ontoaba  Indonesia
ontoaba's Avatar
Hello....
gain of 1
high damping factor
scalable
Btj output devices
That must be voltage follower, I have many version, but all mosfets outputs with floating drivers. I ever trying with bjt and not success. I don't have any no feedback, but all with local and global feedback.
Why not just using multi stage emitter follower? or cascoded one?
Old 15th December 2010, 09:59 PM   #9
Arnulf is offline Arnulf  Europe
gain of 1
high damping factor
scalable
Btj output devices
I posted a schematic of PP buffer here, asking for further pointers and/or alternatives. I went with a version very similar to what I posted in the end and it works perfectly. I have updated schematic somewhere. I used tube front end (6N3P) to drive the 0 dB gain output stage.
As for your requirements: first two fall under same category (add more output devices and adjust drive accordingly), third is a matter of adding another follower to the input if you dislike the existing solution and the latter is a matter of choice (I used BJT integrated darlingtons that many denizens of this forum will shun even though they work just fine). Zero GNFB in the amplifier. Some call it "Zen", others bash it
mod verb, transitive /mod/ to state that one is utterly clueless about the operation of device to be "modded" and into "fixing" things that are not broken; "My new amplifier sounds great so I want to mod it."
Old 16th December 2010, 10:51 AM   #10
Arnulf ...
Would you be so kind and repost the schematics..... can't seem to find it....
I have tried to simulate the alpha20 schematics...both with and gain and unity....It simulates very very well.. but is off course limited to the voltage sving of the Jfets.. app +-25 V....
I have tried to cascode the input with floating bjt cascodes lifted by zeners...It works but...does not simulate very well...and comes to a simulated distortion off 0.02%.. with 40 V sving and 60 V rails...
Lower capacity output CAPS on B1 buffers posible? Harolda Pass Labs 4 15th December 2010 06:25 PM
Chip buffers Atilla Chip Amps 27 9th January 2010 12:49 PM
opamp buffers power output q PederBass Solid State 3 8th October 2004 09:32 PM
three solid buffers,which one is ok? digi01 Chip Amps 0 20th August 2004 08:01 AM
Over-current protection in Audio IC Output Buffers ppl Solid State 1 21st October 2003 06:35 AM
Page generated in 0.12560 seconds (79.46% PHP - 20.54% MySQL) with 11 queries
