Location: Where the world's best tea come from:Kericho Kenya
Hi guys,
I have this 'ancient' amp pcb i want to repair but its really dirty. What do you use to clean pcb?Methylated spirit?Alcohol?Gasoline?...that solvent used in dry cleaning?(i forget the name). Regards Xeclipse
if there are no sparks,it probably doesn't work! |
#2 |
Electrical contact cleaner if it's "dirt". Rosin flux is removed with 99% isopropyl alcohol.
Building a 2.1 system out of a 3/4"x4'x8' sheet |
#3 |
Yes, if you use alcohol, make sure it's 99%....I bought something lesser the first time and the results were not good!
#4 |
Dishwasher then a dehydrator. Worked great on the 1978 Ampex video recorder. Boards look like new. I think your solvent might be 1.1.1 TCE.
G² |
#5 |
Detergent for dust, no doubt it is self cleaning. M3 for plastic or ink removal.
GREAT!! you found ANCIENT PCB. It must be BIG ROCK scratched with copper or orichalc, finger scale drill hole for house scale devices. Also with magic and super enhancements from ancient era. |
#6 |
Its supposed to be white...
#7 |
I use an old toothbrush.
Hard enough to get rid of flux but soft enough not to do any damage.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software. |
#8 |
Chuck it in the dishwasher and then leave it in the sun for the afternoon to dry again. I restore many, many old bits of kit and this method really works the best for whole assemblies. Of course, make 100% sure it's dry before powering up.
The walls between art and engineering exist only in our minds - Theo Jansen |
#9 |
Now that thing really needs a thorough clean up, here's what I do...
Soak the board in detergent solution for 15-20mins, use a shallow basin/bucket etc. just enough for the whole board ![]() I also use kerosene for lighter cleaning you can even test the board while it is still wet, kerosene do not have electrical continuity and will not damage the equipment. It works for me Regards |
#10 |
Water???What of the relay,switches?
| Page generated in 0.13572 seconds (77.94% PHP - 22.06% MySQL) with 11 queries |
