Split off from the thread "Bob Cordells power amplifier book" , this thread will deal with the history , theory , applications ,and simulations associated with the latest , greatest... "devastatingly effective" little trick to grace the AB amplifier.
I have just about completed 4 new TMC capable amplifiers. I only have a 20mhz CRO and 2 DMM's, but hope to "show and tell" in a convincing manner to gain the trust of the community. I also have been running a juryrigged "blameless" based TMC creation plus , SNG001 (member) , has built the finished unit as well. This means it will not blow up , in fact both myself and SNG are enjoying some nice audio. We already know (maybe not everyone ??) The Baxandall Papers: Transitional Miller compensation the history/ basic theory ... let's move on to the application(s). OS
Mongrel website , always current and updated : http://67.248.209.21/D%3A/WEBSITE/ Last edited by ostripper; 12th December 2010 at 11:20 PM. |
#2 |
Real "no brainer" , add the 2 caps and 1 resistor, have 1/10 the total THD , much less at HF. An added bonus of really cutting out the odd harmonics , regardless of topology. I think this is the result of negating the output stage Xover distortion (H3/5/7/9).
A TMC applied AB amp has the output spectra of some of the larger Class A output stages I have worked on / simulated / repaired ... (genesis stealth). Output FFT also matches the Vout FFT of the class A standard EF2 driver stage ... so you are essentially listening to a faithful representation of your VAS. ![]() Quite any easy decision to add 1 more cap / resistor to achieve a tenfold improvement. PIX 1 = no tmc # 2= TMC 100pF/270pF - 470 R network. OS
Mongrel website , always current and updated : http://67.248.209.21/D%3A/WEBSITE/ Last edited by ostripper; 12th December 2010 at 11:46 PM. |
#3 |
I can hardly wait till you incorporate TMC into the KO Goldmund Killer and give some feedback as to the listening experiences.
When board layouts be available?
Thanks Never give a Systems Analyst a screwdriver or hammer
#4 | |
OS
Mongrel website , always current and updated : http://67.248.209.21/D%3A/WEBSITE/ |
#5 |
Hi OS,
Its distortion is low, but has residual of high harmonic. What is the RE of TRs output and Bias? I am suspecting that is in Under Bias! |
#6 |
Nice work OStripper. Looking forward top seeing the performance on the final amp.
#7 | |
I think that's a good point. I'm building a blameless amp at the moment using the Motorola thermaltrac devices. The VAS is the usual EF with beta enhancer using high beta devices - so the potential to reduce OS distortion with TMC is high. I'm looking to minimise the usual dominating odd order distortion spectra - even at low levels so I like the fact that TMC allows the flexibility to add a little more degeneration at the LTP - since the LTP transconductance is no longer the lone force in reducing OS distortion at 20kHz. The fact that a single ended gain stage can now be a determiner of the end THD spectra in a blameless topology can only be a good thing from a SQ POV. To fully realise the benefits possible with TMC is a goal for all of us - and that means optimising the VAS and VAS topology. The poor VAS has often taken a back seat when it comes to creative design thinking. Indeed I can think of a local (Aus) designer that doesn't actually use a VAS. However, with TMC the VAS can now be used to distribute NFB in a way that was not possible before. With TMC it's no longer the least important stage in a blameless generic 3 stage design. |
#8 | |||
Banned
ostripper,
#9 |
If you applied it to a symmetric topology like a leach you'd still get odd order distortion effects wouldn't you?
The profile that we're seeing is really only because it's a singleton type feedback in the case of the Linn and blameless type amplifiers and as a result exhibits single-ended residuals. |
#10 | |
provided it s designed adequatly. The problem for such an implementation in a leach amp arise from the VAS limited gain, hence it will not be as efficient as in a blameless.. One has to increase the gain of this stage, and that s what i did since , for some reasons, i prefer symetrical designs... Last edited by wahab; 13th December 2010 at 11:35 AM. |
| TDA7052A - power, & (real world) heat levels ...Sanity Check sought! | HankMcSpank | Chip Amps | 8 | 11th August 2009 12:17 PM |
| PCM1794 vs. PCM1798 in the real world? | niles | Digital Source | 10 | 14th May 2007 03:27 PM |
| How well does noise measurement in spice match real world? | sonnya | Solid State | 3 | 10th November 2003 07:45 PM |
| Ne5532 Op Amp real world max voltage? | sounder | Parts | 20 | 23rd October 2003 06:32 PM |
| Page generated in 0.11644 seconds (78.56% PHP - 21.44% MySQL) with 11 queries |
