Replacing broken volume control with digital volume control - Page 2 - diyAudio
Old 14th December 2010, 12:07 AM   #11
Thank's Mooly,
The problem is, all the 7 channel using 1 pot rod and motorized, so if I replace 1 of the pot, I must replace all and to make it worse the part is not available...
How about using transistor as buffer to limit the current across the pot?
Old 14th December 2010, 01:09 AM   #12
tomchr is offline tomchr  Canada
tomchr's Avatar
Replacing the pot with another logarithmic/audio taper stereo pot is by far the easiest solution. The Alps pots are quite nice.
If you insist on using a digital solution, I suggest that you replace the pot with an encoder, use a volume control IC (like the Texas Instruments PGA2320) and use a micro controller to read the encoder and control the volume control IC.
~Tom
Old 14th December 2010, 06:16 AM   #13
Mooly's Avatar
Originally Posted by Gunawan W View Post
Thank's Mooly,
If there are 7 separate gangs to the pot... and that's how it reads... then with the greatest respect I do not think you realise how difficult and complex this would be. You would never match the characteristics of an LDR/or Digital arrangement to the others.
Post a picture of it all... and the make and model
Old 14th December 2010, 01:39 PM   #14
BobEllis's Avatar
Hi Mooly,
I don't know how much current...
I only knew that the right channel was broken, maybe it was because my daughter turn it at max at one time when I turn it it on... the amp is 100 watt per channel.
thank's
Are you sure it is the pot and not the right channel amp? What are the symptoms that make you think the pot is broken?
Old 15th December 2010, 01:31 AM   #15
Speedskater's Avatar
From the description of the failure mode, I too doubt that the problem is the pot.
Kevin
Old 15th December 2010, 07:08 AM   #16
Hi Mooly,
it is Yamaha DSP A-970, I can't take picture, because the unit still at my friend.
Hi Bob,
yes it is broken, I already tested it.
Old 15th December 2010, 07:13 AM   #17
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
You can buy a ladder type attenuator kit. It has a pot option: a PIC reads pot's positions and translates it in decibel steps. A stereo ladder attenuator with 4 switchable inputs costs around $50. One of advantages is precision tracking between channels.
The Devil is not so terrible as his math model is!
Old 15th December 2010, 07:22 AM   #18
Mooly's Avatar
Nothing to suggest really... I think trying to source a replacement is the only viable option.
With the greatest respsect do you realise how big a task trying to integrate something like a totally different control system into a commercial product is ? What about maintaining remote volume operation from the same handset... yes it's all do able but it's a monumental task.
It would help to see picture of this thing (the pot). How many gangs etc. Have you tried Yamaha direct for spares... in different countries ? Similar models that use the same pot ?
Old 15th December 2010, 08:17 AM   #19
analog_sa's Avatar
It's really quite easy. Pic any AVR, PIC, etc with an analogue input. A few lines of code and a simple interface to any number of the many available electronic pots. All in a day's work and voila Provided, of course, your time is free and you have some basic knowledge of microcontrollers.
Old 15th December 2010, 10:46 AM   #20
farjon is offline farjon  Brazil
farjon's Avatar
What about this?
audioPT - Pré-amplificador audioPT 1
You can translate it on Google.
digital volume control aardvarkash10 Parts 12 2nd May 2016 07:13 PM
digital volume control Pulse-R Digital Source 4 5th April 2005 01:33 PM
digital volume control sss Digital Source 5 14th October 2003 01:28 PM
Replacing pot with digital volume control puterfixer Digital Source 15 28th October 2001 11:10 AM
Copyright ©1999-2017 diyAudio
