Old 18th July 2003, 12:31 AM   #1
JoeBob is offline JoeBob  Canada
JoeBob's Avatar
Default Would this work?
would this circuit work for a low-pass circuit? Or would the cap after the input impedance setting resistor screw things up?
I ask because if I use a "normal" style PLLXO with a resistor followed by the cap in front of the input impedance setting resistor than the two resistors would make a voltage devider, I would obviously like to avoid that.
Old 18th July 2003, 02:06 AM   #2
JoeBob's Avatar
Oh common, no one even looked at it...
Old 18th July 2003, 02:58 AM   #3
Konrad is offline Konrad  Norway
Put the capacitor in paralell with the feedback resistor!
Old 18th July 2003, 01:32 PM   #4
Default No, it wonŽt...
The -input works as a virtual ground in this configuration so there is no voltage swing there (at least with an ideal opamp). So the capacitor wonŽt contribute anything and could be left out.
As Konrad said, put the capacitor in parallel to the feedback resistor and youŽll be fine.
For calculating the capacitor use the feedback resistor value, not the input resitor value (unless you make them equal for a gain of 1)
Ciao
Andy
Old 18th July 2003, 02:47 PM   #5
JoeBob's Avatar
Ah, I should have thought of that, thanks that helps alot.
Old 18th July 2003, 03:40 PM   #6
Account Disabled
JoeBob, it is one of those "active filter" designs that you can find pretty much in any op amp cook book.
TL and JBL could it work Flodstroem Multi-Way 47 14th July 2006 03:03 AM
Would this work ? LesPaulStandard Instruments and Amps 3 4th May 2006 02:14 AM
Will This Work? sousmielie Class D 6 27th December 2005 05:53 PM
It Should Not Work ! f4bok Solid State 3 6th September 2004 05:33 PM
Page generated in 0.08814 seconds (69.56% PHP - 30.44% MySQL) with 11 queries
