Old 10th December 2010, 02:55 PM   #1
Default 6 Channel Homebuilt amp
Hello I’m new here.
I’ll try to build a 6 cannel amp for my HTPC
I think about 80w8ohms per channel.
I need a print chart/component list
So what do you recommend?
Old 10th December 2010, 03:39 PM   #2
BobEllis's Avatar
Welcome to the world of DIY audio. You'll likely never go back to commercial products. There are lots of amp options. What is your skill level? Any electronics or metalworking experience? If one of those six channels is for your subwoofer, you might want to consider significantly more power for it.
There are a variety of chip amp kits available from several vendors. Until you bridge LM3886s you won't get to 80W, but you really won't notice the difference between 50 and 80W.
Rod Elliot has some good projects and provides good support. P3A is a nice amp 60-80W Power Amplifier, as is P101 although the output devices are a bit more expensive and harder to source.
Check the group buys section for some other PCB options.
For a less intense building experience, check out Aspen Amplifiers Hugh sells some very nice modules ready to bolt into your enclosure and hook up to your power transformer as well as modules for which you will need to supply a heat sink and power supply.
Old 11th December 2010, 09:13 AM   #3
Hello thanks for the reply
What about?
1 X Apex B500
5 X Apex D14
Have Apex A place for his project?
Sincerely
svsommer
Old 11th December 2010, 05:34 PM   #4
BobEllis's Avatar
I don't know that lots of people have built Apex amps like the others I mentioned, but the designs seem sound. Go for it, if you think it will suit. Does he sell boards? Build the smaller amps first and get the hang of it. Larger amps have more potential to make a mess if you've goofed something up.
Old 12th December 2010, 03:45 AM   #5
Bigun is offline Bigun  Canada
Bigun's Avatar
my 2c: You'll need to give some thought to the power supply if you go with a ClassAB amp - 6 channels at 80W is a fair demand which leads to large transformers and slow-start circuitry for powering it up.
If you want to learn about DIY audio then an HT amp gives you plenty of scope to do that. If you want to get a 6 channel amp up and running as soon as possible and still build it yourself then the chip amp suggestion is an excellent one.
I decided my HT amp would be fully home grown, my own power supply and amplifier design. It took at least a year before it was in service.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 12th December 2010, 04:18 AM   #6
I'm a new guy doing pretty much the same thing, but as a nice office (computer) speaker setup. What have you come up with for doing the master volume control?
Old 12th December 2010, 07:32 AM   #7
Hello Bigum
I say
I'm not a shark in this
I have time for it. I think!
I will not design the pcb. I will use a tested PCB
Hello SirNickity
If I understood your question
I use a Gigabyte GA-MA78GM-S2H
to master
Old 12th December 2010, 07:39 AM   #8
Hello Bigum
I say I'm not a shark in this.
I have time for it I think!!
I will not design the PCB I will use a tested PCB
Hello SirNicKity
A&R Cambridge A60 Amp left channel very low distorted barhardy Solid State 3 18th May 2010 08:13 AM
completely homebuilt subwoofer. breisch1986 Subwoofers 1 28th November 2006 09:38 AM
FS: Homebuilt "Aikido" 2A3 single ended triode amp jim_vt Swap Meet 11 21st January 2006 03:38 PM
My 4 channel car Amp distorting on 1 channel (large pics) MikeHunt79 Car Audio 9 3rd September 2003 06:41 AM
Anyone interested in Homebuilt helicopters? ap0the0sis Everything Else 22 29th January 2003 11:14 PM
Page generated in 0.09237 seconds (75.70% PHP - 24.30% MySQL) with 10 queries
