Hi guys, im trying to build the cheapest possible amplifier, at least 50 Watts and low THD
Can someone please tellme some amplifier with that specs? |
#2 | |
You'll need to provide some definition of what you expect in terms of cost and performance or no one will have a clue what to recommend. For instance, are you looking to build under $100, $200??? Is 0.1% THD good enough or do you expect better? Initially, I would recommend a chip amp for most bang for your buck. Sandy |
#3 |
Some chipamps can give 50W of maximum output at less than 10% distortion.
If you follow the instructions correctly you can get up to 60W of maximum output at less than 0.5% distortion.
regards Andrew T. |
#4 |
I want at least 50W of power. and less than 5%THD will be OK!
I build some chipamps (3886, 4780), and sound great, but looking for some discrete ones now. and maybe some other cheaper chipamp |
#5 |
Orden Lenina
If you want to build a discrete amp and do not want to spend too much, maybe you can read about the Mosfet Citation 12 by Nelson Pass or the project 3A from Elliott (few components, truly excellent sound, and he sells excellent pcb for the amp). Pass Labs: Technical articles 60-80W Power Amplifier As for cheaper chipamps, you could try with TDA7394 (Arg. Pesos 15 per device). Good sound overall. Very few components. Good luck, M. |
#7 | |
Regards.......Raj |
#8 | |
Orden Lenina
Good luck, M. |
#9 | |
No need for "exotic" audio transistors if <5% THD will do. In fact I'd go for the TIP3033/2955 in plastic packaging. You should be able to get these for very little money, anywhere. Sandy |
#10 |
Thanks too much guys, will try to find schematics of these amps, thanks!
| Solid state guitar amp | Itbmetal | Instruments and Amps | 8 | 18th May 2009 04:13 PM |
| My first solid state amp | AAK | Solid State | 48 | 10th September 2005 06:38 PM |
| The Solid State Wiki - Your solid state reference guide | Jason | Solid State | 0 | 25th June 2002 05:26 PM |
| Page generated in 0.09887 seconds (78.79% PHP - 21.21% MySQL) with 11 queries |
