Any suggestions would be appreciated. What do you use?
I've got 2 projects that require a light which illuminates when the DAC or preamp is on. The DAC has 120VAC in so it would be easiest to find a small 1/8" red or blue light that will work with 120 VAC. Could I just use a resistor? I am using a Qualtek power entry module and would like to wire the lamp to the on/off switch: http://www.alliedelec.com/search/pro...px?SKU=6894214 The pre-amp can run on 5.5-26 VDC so looking for a small lamp for that too. I've done a lot of searches at Allied Electronics and Newark but all they have are 3/8" dia lamps for 120 VAC. I don't know the right questions to ask them to get the right answer either. Bot lamps will be mounted on a 5/16" thick aluminum faceplate...somehow... |
#2 |
Use LEDs with a series resistor on the DC rails of the power supply. Do this before the regulators if you have any. rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann When your only tool is a hammer, every problem looks like a nail - Abraham Maslow |
#3 |
Getting rid of LEDs and neon lamps from commercial audio components was a tweak years ago. Nobody seems to care about it much these days.
Anyway, I think straight AC on indicators are best on the AC mains side of the circuit and will use whatever I like the look of and drop it to the voltage or brightness I want with resistors. I have some switches that say they use AC LEDs but I don't really know if they're true AC devices or have a rectifier built in. But even if there aren't real AC devices, if you like LEDs it's easy enough to build a little circuit to go with it. Maybe one like this? |
#4 |
Thanks for the replies but I do not want to make this into some laborious project. Don't know about P-S rails or designing a circuit for LED's.
Have a 120 VAC wire and would like to hook a small light to it. That's about it. Is there such a thing? |
#5 |
You can do this.
For mounting on a thick faceplate, I generally mill out the back of the face plate to make it thinner where the LED mounts. If you don't have access to a milling machine or drill press you'll have to be more creative... ~Tom |
#6 | |
#7 | |
#8 |
Hearinspace, I found this but have no idea on its size:
http://www.alliedelec.com/Images/Pro...N/391-0029.PDF and this which looks to be .4" at least: EIKO - LED-120-MB-G - Lamps - Optoelectronics & Lighting - Allied Electronics and this which is over 1/2": SloanLED - 5002-12016 - Indicators, Panel Mount - Optoelectronics & Lighting - Allied Electronics and these but they appear to be over 1/2" dia: Search results for "miniature neon panel mount indicator" - Allied Electronics and this: Search results for "miniature led 120vac" - Allied Electronics I don't really know about this stuff. But searching on and off for 2 weeks. That' why I thought I'd post here. |
#9 |
Well, It's a little hard to know how to answer because you've said you don't want to get into "some laborious project" yet what the guys are advocating above is from the perspective of soldering and mounting only slightly more involved that the little passive pre you've already built - with the one important difference that it involves working with mains voltage and current and getting something wrong there as you know can be dangerous.
I also don't have any idea what tools you've got and what you're comfortable with in terms of drilling holes in the front panel etc. You can make a good looking panel indicator by drilling a 1/16" - 1/8" hole from the front and then using that as a centre guide drill a hole only partially through from the back side of the panel to fit the lamp or LED. But this takes a little care and precision to do well and can look like crap if done badly - especially if the panel is already anodized. If you don't want to get into it then best to take it to a shop or get a DIYer friend in the neighborhood to help. Also something else that I thought last night. If you would actually like to get into this stuff more and the fact that you don't know much is holding you back I would strongly recommend starting with building kits. Good kits with good instructions can teach you a lot and give you guided experience in things like hookup, soldering and also importantly, layout. Start with small/cheap ones and if you find you enjoy the building process then work up from there. In the absence of local friends and mentors it can be overwhelming in the beginning to try to take on the steep learning curve. Better to take advantage of others' expertise and get a happier start. I hope something here is useful. |
#10 |
[QUOTE=chuck55;2391984]Any suggestions would be appreciated. What do you use?
I've got 2 projects that require a light which illuminates when the DAC or preamp is on. The DAC has 120VAC in so it would be easiest to find a small 1/8" red or blue light that will work with 120 VAC. Could I just use a resistor? I am using a Qualtek power entry module and would like to wire the lamp to the on/off switch: Qualtek Electronics Corp. - 761-18/003 - Power Entry Modules (PEM) - Power Products - Allied Electronics The pre-amp can run on 5.5-26 VDC so looking for a small lamp for that too. I've done a lot of searches at Allied Electronics and Newark but all they have are 3/8" dia lamps for 120 VAC. I don't know the right questions to ask them to get the right answer either. Bot lamps will be mounted on a 5/16" thick aluminum faceplate...somehow...[/QUOTE This is what I build and is realy easy. |
| SMPS 230 VAC to 115 VAC 800W | TeeJay | Power Supplies | 88 | 22nd September 2011 07:30 PM |
| KRELL KSA100 conversion 120 to 220 vac | Guy alain | Solid State | 0 | 27th July 2010 09:22 PM |
| Sola Transformer 95-130 VAC In 118 VAC Out 60 VA 60 HZ | Scott Novak | Swap Meet | 1 | 18th April 2009 10:24 AM |
| Onkyo Power Indicator Lamp Out | darth | Solid State | 2 | 5th April 2006 11:55 PM |
| Convert 230 VAC amp to 120 VAC?? | chuck55 | Solid State | 8 | 7th February 2006 01:22 PM |
| Page generated in 0.13335 seconds (80.58% PHP - 19.42% MySQL) with 11 queries |
