Old 4th December 2010, 02:00 PM   #1
Default Amplifier with 2N3055
I was a bit bored and looked over at a disassambled regulated psu that has two 2N3055's in it and thought "i wanna build an amp with that!"
Heres the result after a few hours in simulation:
schematic with sim
Old 4th December 2010, 02:36 PM   #2
First thing I noted is with your diff amp degeneration resistors R9, R16.
You have them shorted out, as your distortion text also indicates.
Sandy
Old 4th December 2010, 04:49 PM   #3
And now its playing:
http://i.imgur.com/LZPi0.jpg
http://i.imgur.com/SwGJg.jpg
This s the schematic on the board:
http://i.imgur.com/WAVUF.jpg
As im posting this, the amp is blasting music at pretty high volume.
Old 4th December 2010, 05:29 PM   #4
godfrey is offline godfrey  South Africa
Originally Posted by Tekko View Post
... two 2N3055's ...
So if you want stereo, it'll have to be single-ended class A.
Hehe - look Ma, only 30W dissipation for 2.5 watts output.
Old 4th December 2010, 05:36 PM   #5
If i want to make a stereo version of this, i'll just get more 2N3055's, their dirt cheap.
This heatsink is way undersized anyways, its already HOT!! And this amp runs only 100mA bias.
I have in a box at my old adress a large heatsink with 8 TO3 devices on them, actually 2 but the other one is clean.
Old 5th December 2010, 11:02 PM   #6
Update:
The two 2N3055's have been replaced with four 2N3716 on a much bigger heatsink.
However making that work was a chore, it took me half a day and loosing a transformer to find out that one of the 2N3716's had a short from c to b.
However once that transistor was disconnected and replaced, the amp sprung to life.
Old 5th December 2010, 11:36 PM   #7
nigelwright7557's Avatar
Update:
Its worth fusing the secondaries to save the transformer if a short occurrs.
I have missed out the fuses myself before on a test rig,
Next thing I knew the transformer was bubbling due to a short !
Luckily i caught it just in time before the windings all melted together.
http://www.murtonpikesystems.co.uk PCBCAD50 pcb design software.
Old 5th December 2010, 11:59 PM   #8
In my case i dident notice it since the transformer was inside a plastic box down on the floor, when i heard the plastic bobbin bubbling and saw the smoke, it was already too late Secondary had already developed interturn shorts.
Old 6th December 2010, 12:38 AM   #9
Pics of prototype:
http://i.imgur.com/gDaaR.jpg
http://i.imgur.com/t8agH.jpg
http://i.imgur.com/aaC9X.jpg
Antithump delay:
http://i.imgur.com/gjs06.jpg
Old 8th December 2010, 09:17 AM   #10
Cleaned it up alittle:
http://i.imgur.com/3FFB1.jpg
http://i.imgur.com/rPFhY.jpg
http://i.imgur.com/XV264.jpg
http://i.imgur.com/yyEeC.jpg
Schematic:
http://i.imgur.com/UlYNn.jpg
It works and sounds really good.
Amplifier based on 2N3055 macgyver Solid State 37 Yesterday 11:27 PM
2N3055 inside - commercial famous amplifier models, quasi complementary power output tiefbassuebertr Solid State 160 11th November 2012 06:04 PM
the ultimate class A 2N3055 amplifier filippo22 Solid State 2 14th June 2003 08:02 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
