Old 2nd December 2010, 10:18 PM   #1
Rafael L's Avatar
Default Phase margin with capacitive load
Hi
I simulated the amp Blameless-D.Self (output EF), with a load of 8R//100nF and the amp has overshoot with this load after measuring the Loop Gain and noticed that it is not PM <180° (Attached).
I am using in the output inductor with a shunt resistor (1uH-10R), output emitter follower, has no stability in capacitive load ?
The simulation is correct , anyone have any comments...
Old 2nd December 2010, 11:18 PM   #2
sregor is offline sregor  United States
Others know more than I, but your phase margin appears to be for unity gain ( 0db) while most amplifers have 26 to 40 db closed loop gain. Assuming dotted line is phase and solid is open loop gain. (26 db gives phase margin of about 95 and 100 respectively)
Steve
Old 2nd December 2010, 11:50 PM   #3
Rafael L's Avatar
Hi sregor, I put the Loop Gain phase margin is in 0dB, if it graph were in Open Loop, the PM would +-26dB.
Old 3rd December 2010, 09:23 AM   #4
Rafael L's Avatar
SCH Amp and Square Waves:
Old 3rd December 2010, 01:58 PM   #5
Bonsai is online now Bonsai  Taiwan
A few things you need to attend to here to improve your situation:-
1. you are running your LTP at far too low current. run it at minimum of 3mA - I prefer 10mA, but some people would say this is too high. 5mA is a good compromise.
2. The current source load in the VAS stage is far too low - you need to set this to about 30mA (on a triple emitter follower, you can get away with 15mA).
3. You need to add some emitter degeneration to your VAS transistor - you cannot run the VAS transistor like you have it without serious problems. Try about 33 Ohms to start off with.
4. I cannot read the value of your LTP mirror load resistors, but they look like 82 Ohms. These need to be about 22 Ohms each.
bonsai
http://www.hifisonix.com/
Old 3rd December 2010, 04:55 PM   #6
Rafael L's Avatar
Hi Bonsai
The values are the same as Blameless published by D.Self
LTP 3.5mA
VAS 5mA
Drivers 5mA
Bias +-110mA (RE 0,22)
The values are 68 Ohms.
The question is loss of PM, more 70° with only 100nF as load.
Leach150 phase margin problem!!! mclarenpingu Solid State 27 3rd March 2008 08:44 AM
Measuring Phase Margin davidallancole Solid State 4 19th December 2007 06:18 AM
oscilating in capacitive load borisov57 Solid State 3 24th January 2003 12:29 PM
Page generated in 0.09196 seconds (74.46% PHP - 25.54% MySQL) with 11 queries
