Old 2nd December 2010, 02:24 AM   #1
smartx21's Avatar
Send a message via MSN to smartx21 Send a message via Skype™ to smartx21
Default 2 Speed Fan Controller
For those who don't like large heatsinks, this fan controller is a good choice.
It is well explained here: Two Speed Temperature Fan PWM Controller - Electronic Circuit Schematics
I slightly changed the circuit to use dual sensors and dual fans, and to be fed from a 24VDC input.
I need support to draw a decent PCB layout! Is alex mm around?
Max.
File Type: jpg 2speedthermofancontroller_1250021666.jpg (32.9 KB, 454 views)
We should not dwell on what we do not have, but, instead, be grateful for what we do have!
Old 2nd December 2010, 10:29 AM   #2
AndrewT is online now AndrewT  Scotland
a suggestion for a little improvement.
Can you insert a timer to allow the opamp to kick start the fan motor with full voltage?
When the timer expires, the NTC determines whether slow speed or full speed is required.
regards Andrew T.
Old 4th December 2010, 02:17 PM   #3
smartx21's Avatar
Also no speed at all....
I see, you mean something like...
Old 4th December 2010, 02:23 PM   #4
smartx21's Avatar
I've inserted a diode in series with opamp output, and then a capacitor from +12V.
It works fine, thanks. It is good to cleanup dirt!
I've also inserted two LEDs, between T3 and T4 collectors and +12V, in order to monitor controller's state. Yellow for mid speed, and red for full speed. So, during power-on, red LED is lit!
Thanks!
Max.
Old 4th December 2010, 02:52 PM   #5
smartx21's Avatar
Default Refined version
Old 6th December 2010, 09:35 AM   #6
Clever modifications !
Thanks.
regards Andrew T.
Old 6th December 2010, 04:35 PM   #7
alex mm is offline alex mm  Romania
alex mm's Avatar
Default Yes Max I'm here....
but not with empty hands I hope you like it .
Alex.
Old 6th December 2010, 04:48 PM   #8
smartx21's Avatar
Very nice!
Are you Merlin, the magician?
Thank you very much!
Old 13th December 2010, 10:56 PM   #9
smartx21's Avatar
Here (Post your Solid State pics here.) you can see some pics of the amp where this fan controller has been inserted in.
Max.
Old 14th December 2010, 12:02 AM   #10
nigelwright7557's Avatar
I designed my own little SMPS with a pot to control the speed.
I used a PIC micro with a PID technique.
It required very few components.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Reducing fan speed 355F1 Power Supplies 20 3rd November 2009 10:48 PM
DC fan speed regulating question sunrise Solid State 23 7th August 2006 04:31 PM
fan speed control flylionking Parts 6 27th June 2005 07:32 AM
Fan speed control jwb Parts 4 25th May 2004 05:33 PM
Page generated in 0.10599 seconds (76.32% PHP - 23.68% MySQL) with 11 queries
