Analysing power requirements (Class-A+C/AB2) - Page 4 - diyAudio
Old 2nd December 2010, 12:14 AM   #31
Bigun is offline Bigun  Canada
Bigun's Avatar
This is weird. after thinking about the current dumping option I found the 1980 paper by Vanderkooy and sent it to the printer.... awhile later my wife (who's not at all involved in my audio addiction) remarks, did you know your daughter plays with his grand daughter ? I just about fell off my chair !
Well it's a darn good read !
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 2nd December 2010, 02:19 AM   #32
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
Can you post a link, please?
The Devil is not so terrible as his math model is!
Old 2nd December 2010, 02:30 AM   #33
I was just going to post the one link but the Google search gets things from different dates.
Results >current dumping 1980 Vanderkooy
Old 2nd December 2010, 03:04 AM   #34
Wavebourn's Avatar
Do you mean this one?
http://quad405.com/jaes.pdf
Old 2nd December 2010, 04:08 AM   #35
Well I was just searching for what Bigun was referring to but I'm pretty sure that's the one he means. They also published a two part article "Current Dumping: Does it work?" in the June and July 1978 issues of Wireless World.
Old 2nd December 2010, 06:04 AM   #36
Wavebourn's Avatar
I don't believe it is a coincidence: I made my "Non-Linear-Approximation-Cheating" design approximately at the same time. Akashic field indeed does exist. Paleontologists insist that an axe of the same form was made of different materials simultaneously in different remote locations on the Earth, as well as kitchenware of similar shapes...
Old 2nd December 2010, 06:30 AM   #37
Wellllll, the three of you are human after all. It seems natural to me that of tens (or hundreds) of thousands of people who grew up learning electronics (or any other discipline) in a world with a given state of the art, it's not weird that at least several of them would be poking around the same frontier. No?
On the other hand, right this very moment MILLIONS of people are dreaming. Just think of it!
Old 2nd December 2010, 12:39 PM   #38
Bigun's Avatar
Yes, this is the one !
It pretty much answers all my questions about this error correction business. Unfortunately, also confirming that you can't escape from using negative feedback at the same time.
Old 6th December 2010, 12:12 AM   #39
jcx is online now jcx  United States
Default Black's Feedforward: a sim
I worked up this "current dumping" Black's Feedforward sim from the jaes paper - sized for a headphone load since I'm using a op amp model with ~30mA output current limit
playing with the signal level it appears that it has the annoying property of increasing distortion as output level is reduced - the max % distortion occurs when the output level just starts to use the "dumper" Q for appreciable load current
feedback is necessary to implement the accurate correction amplifier in Black's Feedforward - I don't believe you can easily combine the sim's op amp and unbiased Q to do better in a "pure negative feedback" topology - so the Feedforward idea is valuable if you insist on "Class C+A"
the shown 2 V sine has ~0.01% output distortion, with the distortion growing to ~0.05% at around 200mV drive
it is hard to not comment on Bigun's several swipes at negative feedback:
use enough closed loop gain in a negative feedback amp with only smooth, low order nonlinearities and you get decreasing levels of harmonic distortion with harmonic order - not the 10-20 dB some "no-feedback" types may tepidly apply - it is easy to have >60 dB loop gain at all audio frequencies
there is no other practical way to obtain useful damping ratios - cathode, source, emitter followers are all 100% (local) negative feedback circuits - there are no "inherently low output impedance" amplifying devices
the "no-feedback" crowd's beloved Triode vacuum tube has loads of internal negative feedback - directly causing the observed plate resistance - a tube without internal feedback is a correctly biased Pentode
negative feedback is a foundational principle and should be properly understood and used correctly - ignore audiophool mythology if you want to learn how to design sucessful circuits
Old 6th December 2010, 01:05 AM   #40
Wavebourn's Avatar
Triode don't have non-linearities of higher orders that are essential to devices linearized by negative feedback.
How can you explain that, if it's a pentode with internal negative feedback?
Here is an example of what happens when negative feedback is applied to the device with 10% of distortions of 2'nd order only:
Triode in Class B or Beam Pentode in Class AB2 rsumperl Tubes / Valves 24 18th July 2010 02:24 PM
EL34 in class AB2 triode mode push-pull? ray_moth Tubes / Valves 29 8th March 2009 07:34 PM
help analysing my main AC power milen007 Everything Else 6 27th June 2008 06:15 PM
How does class AB2 sound? Craig405 Tubes / Valves 25 21st April 2008 07:48 PM
class AB2 who's using it for hifi? richwalters Tubes / Valves 8 8th March 2007 05:21 PM
Copyright 1999-2017 diyAudio
