Old 27th November 2010, 04:15 PM   #1
Audio Junkie
Zero Cool's Avatar
Default Choosing current for LTP?
I just read N.P's excellent article on DIY opamps! Man there is a lot of great info there to digest!!!
I have been reading a lot about Long Tailed Pairs lately and gaining some understanding of there operation. and so now I am curious...and my questions may be too broad to answer i don't know...
But how do you determine what current to run the LTP At? what factors influence this decision?
Zc
It's not about what you can BUY...It's about what you can BUILD!
Old 27th November 2010, 04:26 PM   #2
In general, the bandwidth (fT) will increase as Ic increases. (fT will decrease at relatively high currents, but most likely, you would not use it at such currents.) On the down side, increasing Ic will reduce the differential input impedance and increase the bias currents. So these are the trade-offs and the choice of Ic depends on how important these factors are.
Old 27th November 2010, 06:11 PM   #3
Audio Junkie
Zero Cool's Avatar
and as always there are trade offs. and as usual it sounds very complicated.
Looking at several schematics. it seems 2ma is a common choice?
Old 28th November 2010, 04:56 PM   #4
Rafael L's Avatar
Yes 2ma is a common choice, as higher the current LTP, higher the NFB, but a very high current in LTP more largest DC in base of TRs (BJTs) which increases the noise.
A current mirror doubles the transconductance in LTP, 2ma with a resistor is same as 1ma with current mirror. In my humble opinion, one LTP degenerated into 100 ohms with BC550/560c, max 3,5ma (~50mV on base of TRs).
Old 28th November 2010, 05:19 PM   #5
AndrewT is online now AndrewT  Scotland
if the source impedance is kept low then you will find that high tail current does not increase stage noise significantly.
Adding an RF filtering cap at the +IN input lowers the impedance seen by the base and again helps keep noise low.
LTP tail currents from 0.3mA to 12mA are commonly used.
If you go for high hFE and medium to low Itail then you get low input offset current.
go very high hFE and high Tail current and the input offset current is usually considered OK.
If the two sides of the LTP are carefully matched then input offset current and Tail current do not degrade the output offset.
If you choose transistors designed for low noise then they include noise graphs. These will show IC values against RS with noise curves superimposed. At low Rs you will find that low noise can be had at quite high Id. Whereas high Rs demands low Id to maintain low noise.
regards Andrew T.
Old 28th November 2010, 06:40 PM   #6
Rafael L's Avatar
Hi Andrew
I put an Fig for explain what I was saying, because my English is not good, also forgot to mention that DC is dependent on the impedance of the amp.
The recommendation to keep =<50mV is in the book of D.Self for avoid noise Jhonson (Cap: Small Signal).
Old 28th November 2010, 06:59 PM   #7
Aldotin's Avatar
Iltp=2×pi×fmax×Cl×Vp×X
Iltp: ltp current (A)
fmax: max. frequency
Cm: load capacitance (~Cmiller)
Vp: max. peak o.p. voltage of the Vas
X: min. 3, preferably 6
For a simple conventional 70W/4r audio amplifier using +/-35V rails and BD139 as Vas transistor:
I=2×3.14×20000Hz×100pF×30V×6=2.2mA (1.1mA/leg)
Old 28th November 2010, 07:10 PM   #8
Audio Junkie
Zero Cool's Avatar
ok now i am getting it. that's what I needed!
Old 28th November 2010, 07:33 PM   #9
that is just the calculation for slew rate to allow full power 20kHz operation.
Slew rate should probably be 5 to 10times that to minimise avoidable distortion. recently a poster came back and said 20times might be a better slew to aim for.
That just goes to show why there can be such a big variation, it's a balancing act between all the different effects that result from setting the LTP tail current.
regards Andrew T.
Old 28th November 2010, 08:50 PM   #10
Rafael L's Avatar
In topology that uses Miller CDOM (collector-base of the VAS), the current LTP determines the Slew Rate of amplifier as higher the current LTP, more higher speed have the amp.
Amp Blameless-D.Self uses 3.5mA in LTP with 10K input impedance, if you want to increase input impedance or want more current in LTP, should increase the gain of the differential pair transistors, as mentioned for Andrew...
829B as LTP? DrewP Tubes / Valves 10 17th June 2009 07:00 PM
Choosing from the current crop of t-amps on ebay? den_hr Class D 2 31st May 2009 01:52 PM
LTP question m6tt Tubes / Valves 3 16th February 2009 11:14 PM
ecc40 LTP Jaap Tubes / Valves 17 23rd November 2008 12:22 PM
LTP bias current cunningham Solid State 2 12th January 2005 08:39 PM
Page generated in 0.11068 seconds (76.86% PHP - 23.14% MySQL) with 11 queries
