Old 26th November 2010, 08:11 AM   #1
Question Optonica SA-5207 repair
I was playing a CD and listing to the repaired D-7s when the right speakers fuse blew..... Well I got a fuse, and while trying to replace it (the fuse) while going into the fuse holder sparked in my hand with the volume turned down. So I switched the D-7s off and the Jensen's on. The right speaker Jensen was humming pretty loud. So I shut the speakers off, that is when I saw a small amount of the factory smoke came from the receiver.
When checking the board I saw a diode was burnt 458. <-- I assume it's a diode and that is the stencil number next to it on the board.
Will replacing this repair my receiver? as it was working fine until this happened. Thanks
I bought this receiver new.
I can take pictures of the board and burnt diode if it would help?
Old 27th November 2010, 06:23 AM   #2
Smile Added pictures.
I hope these pictures will help someone to help me.
I have a Marantz SR 480 hooked up while I try to get the Optonica repaired.
And with the speakers I have the Optonica sounds a lot better so I will be glad when I get the Optonica back in service.
Thanks for any help I can get.
Old 27th November 2010, 07:17 AM   #3
jaycee is offline jaycee  United Kingdom
No, something caused the diode and fuse to blow. I see that the amp's based on STK modules - I am betting the module on the heatsink has failed, what part number is on it?
Old 27th November 2010, 07:42 AM   #4
Mooly's Avatar
Or resistor even ... looks like it feeds the driver STK. Perhaps see what pin on that STK it goes too (if it does) or if not where it goes.
STK's are prime suspects. Do not connect speaker until you are sure it's OK (Check for DC at speaker outputs).
A simulation free zone. Design it, build it, test it.
Old 27th November 2010, 08:26 AM   #5
djk is offline djk
djk's Avatar
We have blown a module, I would consider replacing both the output and the voltage module (STK 3042).
The resistor is just a 1K hung on the speaker output to ground. When the module blew up it dumped 30V or more on this and it burned up.
STK 3042 may be replaced by 3062/3082 as well.
http://www.datasheetcatalog.org/data...yo/STK3122.pdf
Candidates for the Darwin Award should not read this author.
Old 27th November 2010, 09:47 AM   #6
Jaycee the part number for the module on the heat sink is ( STK 2240 ) it is a Stereo Power Amplifier.
Old 27th November 2010, 09:49 AM   #7
Mooly I can not tell if it goes to the STK 2240 or not, it doesn't look like it to me.
So I have taken two more pictures to see if that might help.
Old 27th November 2010, 10:01 AM   #8
djk thanks for posting the .pdf file concerning the STK 3042 along with your reply. Is the STK 2240 (picture posted) also available at the same place as the STK 3042?
And I didn't look closely at the .pdf file for a company name or web site to order. And who would you recommend I order it from?
And thanks to every one for there help I really do appreciate it!
Old 27th November 2010, 11:23 AM   #9
Mooly's Avatar
I meant the STK3042 actually as the print runs over in that direction ? If you can't visually trace the print just measure on low ohms (or diode check) from the "R458 marked end" and read down all the pins on the STK one at a time and see if it read short to any pin.
Old 27th November 2010, 03:12 PM   #10
djk is offline djk
djk's Avatar
http://www.datasheetcatalog.org/data...3/133654_1.pdf
Sanyo Sanyo IC 16-pin SIP PIN Base AT 90/degree Angle | STK2250 | Sanyo
Sanyo SUB Only Sanyo IC 15-pin SIP Stk3042a | STK3042 | Sanyo
R458 is a 1K 1/2W carbon film resistor, same as R457 in the other channel.
For Sale: Stage Accompany diaphragms for the SA 8520, SA 8525 and SA 8526. Webbie Swap Meet 6 7th March 2010 06:46 AM
optonica 3636 noise problem sdoom Solid State 4 9th August 2009 07:38 PM
Optonica SX-9100 schematic wanted Shaun Solid State 0 30th October 2007 10:23 AM
Wanted: this relay (used in Optonica & Sanui amps) Shaun Parts 0 14th September 2007 12:44 AM
Data on Optonica speakers? Jonathan Bright Multi-Way 2 20th July 2006 10:38 PM
Page generated in 0.12337 seconds (80.95% PHP - 19.05% MySQL) with 11 queries
