The STK3102-IV is one of the biggest weak spots of some Marantz amps, like the PM80(SE). I had to replace the one in mine once but I was wondering if someone has ever come up with an alternative.
Does anyone know if such an alternative exists? E.g. a replacement made up of discrete components? |
#2 |
http://www.datasheetcatalog.org/data...yo/STK3122.pdf
We can use a higher voltage version, or build a surface mount hybrid (as Crest does).
Candidates for the Darwin Award should not read this author. |
#3 |
Thank you for the link, but that was not exectly what I meant. I was more thinking along the lines of a discrete component replacement that doesn't go wrong like the STK-modules do when they age.
#4 |
Surface mount parts are discrete, and everything eventually dies.
You can build any design you want with surface mount versions of 2N5551/5400 and MJE 340/350 and make it small enough to fit. Crest uses a module they build in their v1500 that will drop right in, don't know what it costs.
#5 |
The hard thing to figure out will be the specifics of the original - such as what was the original LTP current, what was the original VAS current... the circuit itself wouldn't be hard to implement.
| STK3102 MkIII - Chip Amp ?? | poynton | Chip Amps | 4 | 6th November 2007 12:04 PM |
| WTB: STK3102-IV pre-amp module for Marantz PM80 amplifier | rbroer | Swap Meet | 11 | 27th October 2007 07:24 PM |
| Any modification for replacing STK3102-IV | Crecencio | Solid State | 4 | 14th December 2005 12:28 PM |
| STK3102 IV Manantz PM-80SE Amplifier | Crecencio | Parts | 1 | 14th April 2005 02:24 PM |
| IV for PCM1730 | MWP | Digital Source | 4 | 17th October 2002 01:52 PM |
| Page generated in 0.07620 seconds (70.84% PHP - 29.16% MySQL) with 10 queries |
