I need a schematic for transistor Bass & Treble control. If any one have this please send or upload. I made one with LM1036N but I am not satisfied with that. Looking for a better one. I have LM4766T power amp and I will play the tone control with this amp. Thanks in advance.
diptangshu@gmail.com |
#2 |
Hi diptangshu,
Although not transistor based, I can recommend the ESP Hi-Fi Preamplifier by Rod Elliott. I have built this using LM4562 opamps and it sounds very good. His circuit provides a +/- 10dB tone boost/cut, which is rather more subtle than many of the more common designs. Hi-Fi Preamplifier Regards, Steve |
#3 |
Thanks Steve, I will try this schematic but have to design the PCB for it.
#4 | |
Please comment my PCB! |
#5 | |
thanks dude |
#6 |
hello.
found some tonecontrols with transistors............many years ago they were available as a kit............ and there is always the possibility to fiddle around with the parts (bc109c = bc549c,.......) greets Last edited by mjf; 27th November 2010 at 09:36 PM. |
#7 | |
of THD and noise as it s an active baxandall tone control. BC109C can be replaced by BC550C or any generic low noise NPN BC series, BC184C BC309C BC413/414 BC549C , the list is endless... In japanese bjts, 2SC1775 2SC1845 2SC2240 are good candidates. Last edited by wahab; 27th November 2010 at 10:26 PM. |
#8 | |
Thanks MJF, let me try them.
#9 |
Some of the circuits above that specifically state "BC109C" may be relying on the very high gain these devices have (typically around 500), so the 2N3904 with a much lower typical gain may not suffice in all cases. If you want transistor circuits to behave as designed, always use equivalent devices to those specified.
#10 |
........yes,the bc109c is a low noise transistor with big hfe-values (around 500).
here is annother schematic, it was used in mixers,see the multiple inputs....... präsenz = mid control |
| Quad 44 tone control schematic (12784-2) | ANTHONY2181 | Solid State | 19 | 31st December 2010 03:54 PM |
| 2 band transistor tone control | maouna | Solid State | 0 | 31st October 2010 08:58 AM |
| transistor or fet Tone control circuit | maouna | Solid State | 1 | 12th May 2010 03:11 PM |
| Tone control | argonrepublic | Solid State | 0 | 28th February 2010 12:12 AM |
| i need preamp schematics w/o tone control or volume control | hernanstafe | Parts | 7 | 30th January 2008 03:12 AM |
| Page generated in 0.11906 seconds (79.30% PHP - 20.70% MySQL) with 11 queries |
