THD in LTSpice ? - Page 8 - diyAudio
Old 29th November 2010, 07:29 PM   #71
Banned
Why are you complaining on my pics ? You arent complaining on oversize pics posted by others.
Either way these are the last pics, this project is done.
Old 30th November 2010, 08:36 AM   #72
dadod is online now dadod  Croatia
dadod's Avatar
How to plot distortion versa frequency in LTSpice?
dado
Old 30th November 2010, 09:28 AM   #73
jan.didden's Avatar
Originally Posted by AndrewT View Post
what causes the phase "bump" between 3Hz and 500Hz? Is that audible? Does it matter?
87degree phase margin, brilliant.
Does it change much when a little bit of cable capacitance is allowed for?
It's not really a bump. The open loop gain rolls of from about 100Hz.
Then there's a low pass at around 10Hz caused by probably the feedback decoupling cap (or maybe the input coupling cap).
These are two separate things; because they are relatively close on the graph they just look like a bump.
jan didden
Music is dither to the brain; lets me think below the usual chaos - me
Linear Audio Vol 12 is out! Check out my Autoranger and SilentSwitcher
Old 30th November 2010, 01:21 PM   #74
macboy is offline macboy  Canada
dado
Well, you can't plot it, but you can "step" the frequency parameter (look in Help and at the examples). The simulation will run several times at different frequencies and the distortion will be measured each time, assuming you use a .four statement. You can then copy the results from the sim log and chart them in excel.
Old 30th November 2010, 02:37 PM   #75
Banned
And heres the end of this saga:
This amp now plays in stereo and sounding awesome!! Thank you deeply for all the tips and help.
OT: how can I measure THD of my amplifier if my sound card is 0,02% THD ? ygg-it Solid State 1 13th June 2010 08:54 AM
Using LTSpice gaetan8888 Solid State 6 19th July 2007 01:33 AM
RIAA in LTspice Herrmann Tubes / Valves 2 17th September 2004 08:28 PM
LTSpice Issue... mikeks Solid State 17 3rd September 2004 08:42 AM
Ltspice.... mikeks Solid State 10 13th June 2004 09:10 PM
Copyright 1999-2017 diyAudio
