Old 23rd November 2010, 02:31 AM   #1
Default Questions about the 2-pole compensation VAS
Hello
In the Doug. Self Power Amplifier book there is a 2-pole compensation VAS, as you can see in the image I've upload.
In that image you have Cp1 (100 pF) and Cp2 (1 nF) capacitors, what would be the practical resulting cdom Miller capacitance value of that VAS ?
The values of Cp1 and Cp2 capacitors are quite high, how much lower can we go for those capacitors ?
Anybody have try this type of VAS, how good it is, what is the pros and cons of this VAS ?
Thank you
Bye
Gaetan
Old 23rd November 2010, 03:57 AM   #2
jaycee is online now jaycee  United Kingdom
I've not seen the two that far apart before. I simulated it though and it seems to work very well indeed. Here is what I simulated - I have even laid out a PCB for this (a compact one - for a limited size case) but have not yet got around to building it. The CFP drivers may be excessive
Old 23rd November 2010, 04:16 AM   #3
Hello jaycee
The value of C4 and C17 are relatively high, is it because it's a beta enhance vas, have you try much lower caps value ?
Quite all beta enhance vas I've seen used high value cdom capacitors, this type of vas seem prone to oscillate.
Have you calculate the resulting miller capacitance value of your 2-pole comp vas ?
Thank
Bye
Gaetan
Old 23rd November 2010, 04:35 AM   #4
lower values caused oscillation. You'll see also the R-C network in the feedback path, this was also needed. I plotted the loop gain. There is a peak at 500KHz but this doesn't seem to cause a problem. The 0dB point is at about 1.9MHz with a phase of -104 degrees.
In simulation I've thrown square waves and sines at it, and it seems stable. It's also stable into a 1u capacitor, although it needs an L-R parallel network on the output for that.
I think 5th element tried a similar circuit here too, with good results.
Old 23rd November 2010, 04:40 AM   #5
Yes he did. Take a look at this thread:
Slones 11.4 'Blameless'
Old 23rd November 2010, 04:46 AM   #6
Hello
I agree, but high value miller cap slow down the vas.
thank
Bye
Gaetan
Old 23rd November 2010, 06:21 AM   #7
wahab is offline wahab  Algeria
Cp2 value seems uselessly high...
Cp1 value is also high considering that this is a single
transistor VAS that is compensated.
Such a high value would make sense with an enhanced
VAS which would add an common collector bjt to drive
it, as in the blameless.
Typical values would be 100 and 330 pF for an enhanced vas,
56 and 180 pF for a single bjt vas;
Of course, these values are to be adjusted according to the first
stage current capabilities.
To answer your question, although a high value miller cap slow down
an amp, with TPC , its influence is reduced by the resistor that act as
an attenuator, thus limiting the frequency dependent local negative
feed back, and thus extending the vas -3db frequency response..
Old 23rd November 2010, 06:55 AM   #8
Bonsai is offline Bonsai  Taiwan
Jaycee, I think you have plotted the open loop response?
Have you looked at the loop response which will give you a truer idea of your gain and phase margins.
bonsai
http://www.hifisonix.com/
Old 23rd November 2010, 08:00 AM   #9
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
Originally Posted by gaetan8888 View Post
Hello
Thank you
Bye
Gaetan
The way I understand it, the equivalent Cdom would be the series equivalent of 100pF and 1nF (about 90 pF).
BTW, this is extensively discussed in the Bob Cordell thread on negative feedback.
jan didden
/Another new issue: Linear Audio Volume 3!
Old 23rd November 2010, 08:17 AM   #10
Hello
Looking at a Andrew T formula for those two cap, it seem that we need anyway a high value cap.
Anyone have check the slew rate of a amp with a 2-pole compensation VAS compared to the same amp with a standard VAS ?
I've take a look at the Bob Cordell thread on negative feedback, it's a quite long thread to read.
Wen I do amps, using a phase lead cap and a good pcb layout, I can go down to 19 pF for the cdom cap, using a 10 pF phase lead cap, I check it with a 10 khz square wave. It give fast and clean sounding amps (it still need an input section with a good linearity). But I don't use a beta enhance vas.
Thank
Bye
Gaetan
Two-pole compensation for LME49830 monkey29 Chip Amps 0 18th August 2010 06:19 AM
Compensation in balanced VAS GEirin Solid State 19 29th July 2010 11:31 AM
VAS with Miller compensation zero GEirin Solid State 9 28th February 2010 12:36 PM
LME49830 2-pole compensation foo Solid State 0 10th October 2009 09:24 AM
Darlington VAS stage with optimized C dominant pole? Daveis Solid State 2 27th April 2009 02:38 AM
Page generated in 0.11321 seconds (80.50% PHP - 19.50% MySQL) with 11 queries
