Did it Himself
I've made loads of amps in loads of different ways of doing input stages, VAS and output stages, and never yet found one that was perfectly well behaved at turn on or turn off. I can get them to be silent, but there is always a bit of slow movement of the cone in and out. So has anybody come across any amp schematics that they built and there was no movement?
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#2 | |
My blameless's (AX/BX) are so quick to start up you don't even know you turned them on .. not even a barely audible "tick" with your ear on the midrange .. much less any movement. The only way to see this millivolt turn-on is with a scope set to mV/div. This is with these front ends hooked to a 200w - 8 output monster EF2. What type of designs are you getting this cone movement on anyways ??? ![]() OS
Mongrel website , always current and updated : http://67.248.209.21/D%3A/WEBSITE/ |
#3 |
Yeah usually amps that use resistors and boostraped VAS instead of constant current sources behave badly on turn on /off. Symmetrical topologies help here as well.
like four million tons of hydrogen exploding on the sun like the whisper of the termites building castles in the dust |
#4 |
Did it Himself
Well I've tried bootstrapped VAS and CCS VAS, resistive tail LTP, CCS tail LTP, current mirror or not, singleton input, practically everything except cascodes and symetrical topology. Some amps were better than others, but none have been zero movement.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more Last edited by richie00boy; 17th November 2010 at 08:41 AM. |
#5 |
Do you have a softstart ? My 60w amp without one (same blameless module) has more "tick" than my 1KVA 75-0-75v PS with one. (inrush differences)
OS
#6 |
Did it Himself
I have a soft start of about 0.25 second on the primary of the toroid, but the problem is there with and without that and also from a bench DC supply. I don't think this is the issue, the issue should be solved in the amp.
Can you post schematics of your amps that you say have miniscule cone movement, I can't (easily) find anything looking like them on your hosted content nor in threads started by you.
#7 |
There is a mention in the Leach amplifier page about using resistors to supply the current for the ltp input stage (instead of a current source), which as far as i can tell, combine with caps on the zeners to slow the turn on of the input stage. I believe some other amplifiers use similar practices. YMMV.
Steve |
#8 | |
AmpsLab.com |
#9 | |
On shutdown , no woofer movement either ... just a slight distortion as the rails collapse to around 8-0-8V. The BX is just like the AX , but with a bootstrap on the voltage stage. Just a little louder click on startup (200mv/10uS) , still no woofer movement. My DC cap and bootstrap is this series by Nichicon .. (220u and 100u @50V)UVP1H221MHD Nichicon Aluminum Electrolytic Capacitors - Leaded The topology I would want in a room full of nitroglycerin is the CX (below2) .. it has NO tick,click or anything. Must be the 5 device balanced VAS that does this. OS
#10 |
Did it Himself
100uF. And quite spookily the same resistors as ostripper, 33k and 820R.
| Burr Brown op amps,in amps,power op amps for sale | magneticnorth | Vendor's Bazaar | 1 | 23rd September 2010 10:50 PM |
| Criteria for well behaved clipping | panson_hk | Solid State | 1 | 9th August 2010 02:35 PM |
| which NAD older generation amps & integrated amps are bipolar or mosfet? | audionaut99 | Solid State | 3 | 21st May 2010 10:09 AM |
| For Sale: Tube Amps, Class-A Amps, BG Ribbons, Chassis and Other Goodies! | opc | Swap Meet | 23 | 2nd November 2009 05:04 PM |
| Has anyone compared GC amps(LM3875/3886/4780) with other DIY SS amps(Leach,ESP) ? | percy | Chip Amps | 31 | 13th January 2006 01:33 AM |
| Page generated in 0.11313 seconds (77.86% PHP - 22.14% MySQL) with 11 queries |
