After having cloned the Electrocompaniet AW120 albeit in a lower power variant (attached picture), I will now be attempting to clone a higher-power EC amp. If anyone has such an EC schematic...
'in acts and works bigger than a great wale's tail' |
#2 |
My effort so far.
#3 |
Hi Hollowman
Looks very neat -- Just a point on construction - It may benefit to have the incoming power to take the shortest possible journey -- it looks like the cord travels all the way around the box. Otherwise it could be more opportunity for interference to inject into the signal paths, creating that little background bzzzzz nobody likes.. Does the model number suggest the power? 120Watt? Have you tested it's performance? It's nicely laid out. I suppose one could configure it in conventional dual mono with two transformers as the separate power supplies exist -- but I realise this hikes the cost up Also it looks like most of the items in contact with the heatsink are TO220 style is this correct? Thermal management is improved if the surface of the heatsink is used to better effect - efficient use of the flat area of "real-estate" that can be used to distribute the thermal load. - rather than grouping all the components together in one corner. Nice practical looking design that could be made modular so that it could be constructed into a 5x or 7x amplifier variant for THX, DTS and DOLBY surround fairly easily
Hum likes to have a nice "Noise to Signal" ratio To "Hum" is to be noticed Last edited by PhaseLockLoopy; 14th November 2010 at 07:31 AM. Reason: because I cant goddam spell.....ok? ;) |
#4 |
Any pictures of the internals maybe from an AW250 (or similar)?
Thanks.
#5 |
Don't rush, there's room for all!
I will be continuing with my new project, to clone a AW250 or AW400, the aim being to make electrocompaniet engineers blush on sighting!
#6 |
Hollow, sorry Im away from home and terribly busy at the moment, I will get a friend of mine to visit my home PC and email me a copy of the schematic which I will then send to you.
#7 |
Thanks very much homemodder, that'd be a lot of help!
#8 |
Main board getting toward completion, Homemodder I would be indebted if you could mail me that schematic
#9 |
Hello Hollow_man,
Is it an idea, since you "copy" the more modern versions, to create the never produced "Perfect Two-Channel" ? That would be a challenge Without cascode-follower: roughly 35Watts(8ohm), regulated and separated power supplies, different transistors. We are 35 years after date, there are transistors out since then that could do the job done the right way the original drawings I mean (!) It does run hot |
#10 |
Hello Sorscha,
I am not attempting to clone the 'the two channel amplifier'. My clone is based on quite late electro designs, it does not use cascoded stages, nor does it use outdated output transistors. If you read my earlier posts again you you will see that I have already cloned an AW120-ish, circa 2002, and I am now attempting to expand this to 250-400Watts. But it's been f***ing hard work so far and nobody bothered to help with the EC schematics.
'in acts and works bigger than a great wale's tail' Last edited by hollow_man; 3rd January 2011 at 06:51 PM. |
| Did someone clone an Electrocompaniet AW amplifier? | vzs | Solid State | 35 | 12th October 2009 05:19 AM |
| Wanted - High Power, High Voltage, Audio Frequency Transformer Manual. | kimbal | Tubes / Valves | 4 | 11th May 2009 08:05 PM |
| Adding a 12V power trigger switch to Electrocompaniet Power Amp | maxzimum | Solid State | 0 | 11th April 2008 01:54 PM |
| Electrocompaniet 100DMB power Amp | jjbmon | Solid State | 0 | 25th July 2007 11:13 PM |
| Page generated in 1.71110 seconds (5.06% PHP - 94.94% MySQL) with 11 queries |
