will pay for Belles 1 Series amp info & Schematic
Old 11th November 2010, 07:55 AM   #1
gp4Jesus is offline gp4Jesus  United States
Default will pay for Belles 1 Series amp info & Schematic
thread title says it all.
Have DC problem to trouble shoot in 2 units.
Both amps, under the same circumstances. 1 produces very faint clicks, the other pops loudly in left channel.
Hafler xl-280; direct coupled-dead silent!
REALLY want the schematic.
Thnx advance tony
Samsung 60" LED, Outlaw 975 prepro, Samsung BDP, Charter DVR; Tri-amped(!) LR: Parasound 855 & 2 Rotel 980s ->Polk RTi A7 ; Tri-amped(!) CC: Rotel 985 ->Polk CSi A6; Mackie 1400->DVC 15 Sub; Surrounds: Hafler XL280->Polk RTi A3
Old 17th November 2010, 05:51 PM   #2
tiefbassuebertr is offline tiefbassuebertr  Germany
tiefbassuebertr's Avatar
Today I will ask for navigation instructions to find the appropriate download aera about
www.powermodules.com
Unfortunately I am not able to find it without help.
At most websites such aeras not so easy to find like at Crown's homepage.
I need schematics of several currently available and vintage models (quickly the reference power amp 350A).
Old 17th November 2010, 10:40 PM   #3
I have two Belles 1 Series power amps; appropriately nick named "Clicker" & "Popper."
Clicker "clicks" & Popper "pops when changing surround sound decoding or some operations on DVD player.
Clicker's ser#: 134; Popper's ser#: 228. This is importan because the driver board's layouts differ considerably.
DC offset: Clicker's 33mv & -74mv; Popper's 150mv & 1.03Volts! YES you read that right 1.03V!
I sent an email to www.powermodules.com requesting a schematic though I don't it to pan out.
thanks tony
Old 18th November 2010, 02:08 PM   #4
Bottom line: don't expect any schematics.
Spoke to Dave Belles himself, today. He considers schematics intellectual property & won't hand out or sell them.
If you DO get one, my PP account is ready.
Tony
Old 25th November 2010, 10:35 AM   #5
Tony
Thank you for that info. This means "reverse engineering" in case of wanted schematic.
Fortunately the topology by my model "350A Reference" is easy (cascoded differential amp with current mirror and dual BjT "LM394" in the front end so as audio lateral MOSFET's from Exicon in the output).
But I don't know the exactly recommend value for the idle current. I guess 100-150mA/each Exicon MOSFET pair.
Additional an outdoor inrush current limiter is necessary to switch on six stereo devices of that model at the same time.
Old 25th November 2010, 01:27 PM   #6
Default Belles Reverse Engineering
Yeah, "reverse engineering." Compared to a Hafler XL-280*, the Belles is VERY simple. I scheched out the PCB on 11X17 paper & drew in the components.
* using 280 schematic to help me
Unfortunately, I can't figure out what a couple of components are. One of the driver transistors has colored stripes accross it; the other, marked 41011. Can't locate info on the 41011. Started a diy thread for answers.
Can't make out what two tan colored things are, either radial caps or resistors. I expect to remove to test. Diodes have a mark or stripe at cathode end, right?
Finally I may have "bit off more than I can chew" as my EE background is limited compared to most, but that won't stop me from trying.
...topology: cascoded differential amp with current mirror
Sorry I don't know what this means. But for all either of us knows, Belles may have used similar if not the same topology, just newer components in your 350! Google Rod Elliot. He does that in many of his power amps designs.
and dual BjT "LM394" in the front end...
Has 3 transistors (FETs?), 8099s* & 8599s*, per side before the drivers (41011 one side, the other??); all discrete components, no chips;
* appears to have 1 8099 & 2 8599s on one side; 2 8099s & 1 8599 on the other. Finishing the schematic may prove otherwise
6 bi-polars per channel in output.
I think you guessed right. Click here for a long-winded confirmation. My Belles doesn't have a bias POT. If I can get DC offset problem licked, that should be easy. I noticed a 1 or 2 resistors w/out a "twin."
Adjusting the Bias Of Your Amp [English]
We both love our awesome amps. I understand Belles' attitude for your late model amp. Mine are 25 years old!!
thanks for reading this far; Keep me posted on what you learn
cheers tony
Old 25th November 2010, 01:44 PM   #7
h_a is offline h_a  Europe
h_a's Avatar
Any potentiometers on board?
Old 25th November 2010, 01:59 PM   #8
None! I'm certain of it. read my previous post
tony
Old 25th November 2010, 08:54 PM   #9
Can you post some pictures (outside front/Rear/top view inside) ??
I cannot find any informations about the amp model "1 Series" from Power Modules/David Belles - obviously there are only few devices produced (maybe first power amp device from David Belles).
41011 sounds like custom made BjT's from RCA/Harris - check also the logo
8099/8599 could be that type:
http://www.classiccmp.org/rtellason/...ta/ksp8098.pdf
http://www.classiccmp.org/rtellason/...ta/ksp8598.pdf
http://www.datasheetcatalog.org/data...la/MPS8598.pdf
The first steps you must perform is follow:
1) create schematic diagram
2) replace all electrolytic caps - if still DC offset present,
3) measuring of the DC conditions by shorted input and
4) starting the actually trouble shooting
concerning the not presently variable resistor: either at this place was put in a normally resistor after adjusting a potentiometer (NAD 3130 works in this kind) or an idle current servo circuit (instead a commonly used Vbe multiplier) is in use.
I guess, the topology is a normal differential input amp without current source and current mirror so as one stage VAS without Ube current source but with bootstrap cap to the output like "Citation 12"
http://www.passdiy.com/pdf/citation.pdf (Fig 7)
Pass mosfet citation 12 clone
Old 25th November 2010, 10:17 PM   #10
I'll post pics of PCB too-Popper partially disassembled to draw schematic.
I cannot find any information about the amp model "1 Series" from Power Modules/David Belles - obviously there are only few devices produced (maybe first power amp device from David Belles).
Yeah you won't any info on Power Modules.com about these or any other pre early-mid 90s designs*. Several times a year you'll see any of these come up for auction on ebay-that's where I got Popper, my 2nd one.
* 100, 200, Class A mono blocks about 2 weeks ago, "2"-the baby brother to "1"
the 41011 is screwed to a heat sink that's then screwed to the PCB. I'll have to look on the heat sink side.
I remember a Motorola symbol on either 8099 or 8599
working on it-tough w/9 kids! I squeeze in editing (a text file)between crisses then copy/paste to a reply window.
Should be easy-only 3. Then check offset again? Here's where I'm fuzzy on your advice
If DC offset still present,
measure w/shorted inputs (?) If offset still bad, then start the trouble shooting?
Vbe multiplier
differential input amp* without current source** and current mirror...
VAS without Ube current source...bootstrap cap to the output...
I've heard the XL280 use this*. Except for **, I do not know what any of these other terms mean. I see VAS in many other amp threads-haven't gotten to asking what it means.
I look forward to checking these links. a previous reply sent me a link that suggested info for the 41011, but no trace to its twin
I'll PM the schematic to ya.
thanks a million for your help,tony
will pay for Belles 1 Series amp info & SchematicHide this!Advertise here!
Belles 1 Series amp Schematic gp4Jesus Solid State 0 30th October 2010 06:08 AM
Belles Series 1 power/current rating gp4Jesus Solid State 1 9th August 2010 01:52 AM
Schematic for Belles 150A F1 FAN Solid State 0 28th May 2009 03:06 AM
Old Belles Two amp ? Jozef Solid State 0 6th February 2007 02:40 PM
Belles Series I for sub duty gp4Jesus Solid State 0 16th November 2006 12:42 PM
Copyright ©1999-2017 diyAudio
