I have modded a couple of preamps by upgrading caps, resistors and diodes with a noticeable difference in sound but when it comes to bypassing caps, I dont hear the difference at all as I did when doing other upgrades, after extensive listening I have tried A/B comparisons bypassed vs none and have not noticed any difference in sound on a couple of different preamps and power amps, I have bypassed caps in the PS and audio path.
I know there is a lot of controversy on the bypassing topic and perhaps some of you can post your results, positive or negative. |
#2 |
IMHO, real bypassing is possible only in DIY units, since industrial ones do not allow enough space for 50...100uF polypropilene shunts. 0,1...1uF shunts can not serve as audible measures, they can only improve or make worse high frequency oscillation artefacts, visible at square wave tests.
#3 |
I find the biggest differences when bypassing the 20,000µF main filter caps in power amplifier power supplies with caps in the range of 22F~100µF, and a lot less of a difference in preamp supplies (which are generally regulated anyway).
The next biggest change I hear is in signal coupling caps when using film bypass in the range of 0.01µF~0.1µF in parallel with electrolytics in the range of 10µF(typical input cap) ~470µF (typical feedback cap) or so. The first change makes the bass sound 'tighter', the second makes the mids and HF sound more 'detailed'. Obviously, if you like 'warm' sounding bass and 'soft' sounding highs you may want to listen to the result before making any permanent changes.
Candidates for the Darwin Award should not read this author. |
#4 |
Where do you find affordable film caps in high values upwards of 50uF?
Sam |
#5 |
motor start (for lower voltage) and motor run (for higher voltage) capacitors.
Don't use the electrolytic type.
regards Andrew T. |
#6 | |
There is always a first time.... |
#7 |
Here is my standard set of important caps for Zen-like SE class A designs. Main output cap is from low-ESR electrolytics (solid electrolyte), 68uF polypropilene shunt to it, 56uF polypropilene shunt at power rail after virtual battery circuit, 50uF mylar shunt for power rail before the virtual battery.
All this makes sense if one intends to get close to tube-like SE sound. Last edited by VladimirK; 9th November 2010 at 04:02 AM. |
| WTB :V-caps cfcf or cucf for bypassing | gregdee | Swap Meet | 1 | 1st June 2011 10:11 PM |
| Delta 1010 Mods: op-Amps, Caps, power supply, clock | hendrikxix | Digital Source | 2 | 31st May 2008 04:48 PM |
| bypass caps for bypassing mylar caps? | crippledchicken | Multi-Way | 4 | 27th February 2008 04:24 AM |
| Preamps in Class D amps. | Bgt | Class D | 0 | 17th November 2006 02:58 PM |
| Bypassing bias stage with caps | EchoWars | Solid State | 5 | 21st November 2003 08:16 AM |
| Page generated in 0.10036 seconds (74.84% PHP - 25.16% MySQL) with 11 queries |
