L-MOSFET G.Randy Slone
Old 31st October 2010, 08:56 PM   #1
macgman2000 is offline macgman2000  United States
Question L-MOSFET G.Randy Slone
Hello,
I am relatively new to the DIY high power audio scene. I specialize in a different branch of electronics and thought I would work on an audio DIY amp for experimentation. I picked up G. Randy Slone's High-Power Audio amplifier contruction manual.
Art work 11.8 with the L-MOSFET configuration is what I am interested in. To photo etch the board is going to be a problem since he over layed the parts outline and numbers on the top view of the PCB artwork. The photo etch is going to reproduce the component outline and short out traces.Does anyone have a clean version without all the overlay clutter?
Thanks,
Nick
Old 31st October 2010, 10:25 PM   #2
richie00boy is offline richie00boy  United Kingdom
Did it Himself
richie00boy's Avatar
One of the amps in his book will never work and I think it may have been that one. It's been covered on here in depth. Have a search before you potentially burn all your parts.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 1st November 2010, 10:14 PM   #3
mlloyd1 is offline mlloyd1  United States
mlloyd1's Avatar
the one to avoid was the one with the complementary symmetry (npn and pnp diff amp) input stage with current mirror loads.
the other projects were "safe"
mlloyd1
Old 2nd November 2010, 01:14 AM   #4
Question which schematic?
Does anyone have the High-power audio amplifier construction manual by Randy? Is the amplifier featured in figure 11.8 the infamous problem amp? Or is the 11.8 amp a good design?
There are a couple of L-mosfet amps in the book, not sure which one it is.
Thanks,
Nick
Old 2nd November 2010, 03:16 AM   #5
mlloyd1's Avatar
ok, i'll try again.
take a peek in this thread:
http://www.diyaudio.com/forums/solid...-troubles.html
mlloyd1
Old 2nd November 2010, 11:03 AM   #6
alex mm is offline alex mm  Romania
alex mm's Avatar
Default PCB ....LMOSFET amplifier
Hi, PCB layout in 2009 may help you someway ......
Alex.
Old 2nd November 2010, 12:40 PM   #7
Thanks for the info !!! I am sure I will have even more questions trying to make sense of it all.
Nick
Old 24th January 2011, 04:37 AM   #8
wojo411 is offline wojo411  United States
Dude, art work shouldn't be a problem. Appendix Figure C.11 is the artwork for the amp in Figure 11.8. Figure C.9 & C.10 include the components on the artwork for reference when you're filling the board.
Now, the current mirror on the differential input stage, I understand, might be a problem. Never tried it. Good Luck.
L-MOSFET G.Randy SloneHide this!Advertise here!
Randy Slone 6.6 design py Solid State 8 20th July 2011 02:06 PM
Randy Slone Passes Bluetron Solid State 51 8th January 2011 10:05 AM
Randy Slone JDDCo Solid State 6 22nd September 2006 02:57 AM
Randy Slone: Opti-MOS pixie Solid State 73 12th September 2004 07:57 AM
OPTIMOS-Amp from Randy Slone wopo Solid State 1 12th July 2004 08:18 PM
Copyright ©1999-2017 diyAudio
