Hi guys
I just started a new discrete transisitor Pre-amplifier inspired by a Mark levinson Great until i finished regulating for 15volt rails Got the thing slung together and I have been chasing my tail on noise ever since only to now find it's coming from Zeners............. ooooh yes what fun Typically my regulator circuits follow the pic -- (see pic) Interesting is the spectral density of the noise If i get my soldering iron close to them the density and type of noise changes - suggesting thermal fluctuations linked to electron avalanche effect as per Boltzmans constant The problem is I have swapped Zener after Zener after Zener with no improvment Has anyone else had a tearing of hair moment with Zeners i love noise -- dont you ? ....ooooooooooh joy
Hum likes to have a nice "Noise to Signal" ratio To "Hum" is to be noticed |
#2 |
That design must have super poor PSRR if that regulator ain't low enough noise... Anyway, the zener should be running at > 1 mA for reasonably low noise--at low currents multi-state noise (random changes between two potentials, similar to popcorn noise) appears and also the white noise content increases. Too lazy to calculate the zener current, but intuition suggests that it might be pretty low at low output currents. I'd go for a topology where zener current is well defined and independent of output current.
Further enhancements include the use of lower voltage diodes (3x 5.1 V will give *much* lower noise) and increased filtering. Samuel |
#3 |
Don't u need resistors to feed the 2955 and 3055 bases from the unput supply in order for the thing to work ?
#4 |
are Q1 & Q4 wired correctly? What is the purpose of R2 & R5? What is the purpose of the two Vr?
regards Andrew T. |
#5 |
All zeners are noisy, it is just that some are noisier than others. That is why they are used as noise sources. If you want low noise then bypass with a fat capacitor.
I don't understand your circuit. It seems to rely on the output transistors having large c-b leakage. Are there components missing or in the wrong place? Why have you inserted a noisy 'regulator' between big capacitors? |
#6 |
Zeners, noisy? Hmmmm Yep, they are. This is why I don't use Zeners as voltage references in regulators where noise is an issue. I prefer to use a lower conductance low noise J-fet at Idss and cascode with another of higher Vgs at Idss of the lower conductance one. Then the constant current through a constant resistor, metal film of course, gives a constant voltage. Place a few nf cap across the resistor to diminish Johnson noise. Now you have a much better voltage reference.
All the trouble I've ever been in started out as fun...... |
#7 |
Once again I'd like to thank Christer for sharing his measurements: Some noise measurements for LEDs and zener diodes
He shares a summary of his findings in post #65: Some noise measurements for LEDs and zener diodes
Gravity - Making the G since 13.7 billion B.C. |
#9 | |
jan didden
/Another new issue: Linear Audio Volume 3! |
#10 |
Will this cct work? Q2 is trying to pull current out of the base of Q1 instead of feeding it into the base. EDIT: Sorry just read last post: What janneman says.
| zener regulator | till | Solid State | 29 | 26th March 2008 09:39 PM |
| How do I identify a zener value | Paulr | Parts | 5 | 14th June 2006 05:30 PM |
| Zener references | rtarbell | Solid State | 9 | 6th November 2005 10:45 AM |
| C27ph Zener - help | marijan | Parts | 3 | 26th September 2004 05:24 PM |
| No zener | ding | Pass Labs | 10 | 6th June 2001 11:11 AM |
| Page generated in 0.13819 seconds (81.10% PHP - 18.90% MySQL) with 11 queries |
