Ok, I have two (2) 8000 VA toroidal transformers, 230 volt input with dual 88 volt secondaries.
Anyone up for building a REALLY MANLY amplifier ? MAybe a six channel project 117 Almost Halloween....MONSTER amp....anyone need a couple LARGE transformers ?
none |
#2 |
photo's please...
OS
Mongrel website , always current and updated : http://67.248.209.21/D%3A/WEBSITE/ |
#3 |
If anyone builds that amp, here's the classic track to demo it on 10/31/2010!
Bobby Boris Pickett-Monster Mash YouTube - Halloween! - Bobby Pickett - Monster Mash - (HD Stereo) A 45 (too bad, not LP) on a nice-looking linear-tracking turntable.
A stiff power supply in a great-sounding amp is always better for you than a stiff drink.
#4 |
Actually 8245 VA, 0-88-120 Volt outputs, wire is 8 gauge....and these things
are REALLY heavy.
none |
#5 |
Looks like these puppies are right up your street OS, I can see you playing harmonica through an arc-welder with these
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig. |
#6 | |
![]() ![]() What I don't have is a speaker that can handle 1.5KW. Try to sell/trade them at the swap meet section of DIYA. Nico Ras's "big booty amp" ![]() would eat these puppies right up. They are industrial isolation trafo's for deriving 120v to power remote instrumentation in a factory.... they would have to be rewound to be useful for audio. You could use them in the US hooked up to the range circuit .. they would Definitely!! cut out any 15/20A typical household circuit. OS
Mongrel website , always current and updated : http://67.248.209.21/D%3A/WEBSITE/ Last edited by ostripper; 24th October 2010 at 03:40 AM. |
#7 |
`I would wire them up as 120-32-0-32-120.
This would give about ±45V and about ± 170V. I would run it class AB+G. The transistors on the lower rails would need to be a minimum of 215V, the transistors on the upper rail need be only 125V minimum. I would probably use eight pair of MJ21195/96 per rail (32 outputs per channel), or a dozen pair if you wanted to use plastic (48 outputs per channel). In normal use I doubt if it would ever get out of class AB (200W/4R), so you could bias it up hard for good class A power (up until your heatsinks got to 150°F or so). A Crest 9001 runs on about the same voltage, with about the same number of outputs, ±161V peak output.
Candidates for the Darwin Award should not read this author. Last edited by djk; 24th October 2010 at 08:57 AM. |
#8 |
#9 |
APEX audio's class H 1KW would be a very good candidate as well. I would not want to buy all those caps , even through APEX JR.... 2 X 100V samwha's in series...
![]() OS
#10 |
Integrated Class A stereo amp + room heater. Perfect for Alaska or northen Canada somewhere.
| beta22 - a real interesting headphone amp | peranders | Headphone Systems | 8 | 10th January 2009 03:53 PM |
| A REAL 1500w amp! | DragonMaster | Car Audio | 46 | 14th June 2006 05:18 PM |
| 600 *REAL* watts amp? | hipyo | Car Audio | 89 | 9th September 2005 02:52 PM |
| Page generated in 0.11034 seconds (78.92% PHP - 21.08% MySQL) with 11 queries |
