I have an old philips record player with CERAMIC PICKUP. Can any one suggest any good sounding preamp for that? That can be made with transistor or IC, not an issue. Output needed 2V p to p
#2 |
Banned
If I remember correctly the output from these is so high that a preamp is not required. You should be careful before using it on any valuable vinyl as it may damage it. Inspect the stylus with a magnifier, test anyway on something unimportant.
w You can easily construct an amp with a few dB of gain using an opamp, say an NE5532 (cheap). Last edited by wakibaki; 22nd October 2010 at 11:24 AM. |
#3 |
Ceramic pickups vary in output, generally the better quality have lower output. From memory the typical output is a few 100mV, so you probably need a gain of 10-20 to get your required 2V. However, some ceramics will generate volts, as wakibaki says, so you might just need a follower as a buffer. They need a high impedance input, say 1M. Too low an impedance loses bass, as the pickup looks like a capacitance in series with a voltage generator.
I would use a cheap JFET input opamp, such as TL071 or LF351 series, in the non-inverting configuration. This means that the 1M input would not create much offset, as it might with a bipolar input amp, because a JFET input has virtually no bias current. Adjust the feedback resistors to get the gain you need. |
#4 |
#5 | |
Thanks to everyone. Elvee the last link "Transistor tutorial Audio Amplifiers, Part 5" I liked much. Thanks again |
#6 |
Here good schematic for ceramic pickup. Cheers! Last edited by formula 22; 6th April 2012 at 07:38 AM. |
#7 |
#8 |
Yes with LF353.
This is a better schematics which can be changed a gain with trimmer of 10k or 100k ! Cheers! Last edited by formula 22; 6th April 2012 at 08:06 AM. |
#9 |
This is a better schematics which can be changed a gain with trimmer of 10k or (1....470k). This schematic is for the stereo to mono use OA: NE5534, LF351, TL071, OP123, etc., while attention should be paid to the pins OA? Input resistance changes with the input resistor connected to ground (1MOhm) To enter this violin pickup resistor should be about 4,7 MOhm! Best regards! Last edited by formula 22; 6th April 2012 at 08:51 AM. |
| Guitar pickup balanced preamp | MisterStarshine | Instruments and Amps | 31 | 16th May 2009 08:48 PM |
| Ceramic or Magnetic with new preamp? | jn2630 | Tubes / Valves | 6 | 26th January 2008 06:21 PM |
| krell 300i preamp schematic needed | soundcrafters | Solid State | 1 | 16th August 2007 09:53 PM |
| Laser pickup needed | georgehifi | Digital Source | 4 | 23rd May 2005 11:02 PM |
| Page generated in 0.11639 seconds (76.01% PHP - 23.99% MySQL) with 11 queries |
