Old 18th October 2010, 05:02 PM   #1
Default Sansui AU G33X protector at higher volume
Hello,
I have a problem with my Sansui AU-G33X amplifier. It works fine at lower sound levels, but as soon as I crank up the volume the protector circuit kicks in. After the normal blinking the amp starts working again. I tried and it is only related to the right channel. A few months ago I adjusted bias and checked for DC voltage, so all should still be fine.
Of course this unit is from 1983 and I did not yet replace the capacitors.
Any suggestions where to start looking?
Thanks for your advice,
Nijs
Old 18th October 2010, 09:42 PM   #2
I would check you speakers and speaker wires, one little stray strand of speaker wire touching from + to - will cause this to happenas soon as a little power is added. Or if your speakers are 4 ohm and when you turn up the music it drops down to less ohm's as the the bass is a kick'n, bam, the speaker protection comes on. I have a Sansui and thats what I found would happen. If you have, or, can try a differance pair of speakers I would do that first before digging in to the amp.
Old 18th October 2010, 09:54 PM   #3
zeonrider's Avatar
Originally Posted by Alfanijs View Post
Hello,
Check otput impedance eg. speaker impedance!
Regards zeoN_Rider
Old 19th October 2010, 08:54 AM   #4
Thanks both of you for your replies. You were spot on Rapidroy - it was a stray strand of speaker wire! DC resistance was 1.4 Ohms... Of course I read your messages too late and I discovered this only after replacing all el. caps in the power amp circuitry. Worst thing is I made the speaker cables myself and they had been running without problems on my B2101 power amp, even at higher volume levels - shows again what a beast this is! So I did not suspect the cables or speakers at all.
Everything is fine now. Thanks again!
sansui au-6900 newf Solid State 8 25th May 2010 01:08 AM
Sansui AU 11000 jeff11 Solid State 8 30th January 2010 10:18 AM
Sansui AU-X901 tone2222 Swap Meet 4 31st May 2007 05:36 AM
Sansui AU-111 stonehome Swap Meet 1 14th June 2006 02:37 PM
Sansui Au-517&au-717 ManUtd Solid State 4 29th March 2004 01:13 AM
Page generated in 0.07983 seconds (71.35% PHP - 28.65% MySQL) with 10 queries
