Old 15th October 2010, 09:54 PM   #1
Stee is offline Stee  Italy
Stee's Avatar
Default Hybrid project with inverted SRPP
because G3 PHENIX works so good
(I think is a version from Aikido)
I would like use the same configuration in Bipolar output stage
what do you think?
visit my best audio idea http://www.esafono.it/DACTONE.htm
Old 17th October 2010, 07:37 AM   #2
Stee's Avatar
Default JLH AIKIDO
so in that way borne the JLH Aikido version
Old 17th October 2010, 09:41 PM   #3
nigelwright7557's Avatar
From my calculations that amp has a huge gain and will clip very easily.
I designed a very similar amp with SRPP front end but with MOSFTE outputs and it sounds very clean.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 18th October 2010, 06:20 PM   #4
Stee's Avatar
Default on simulator
synthesis is just awful, and the capacitor causes phase shift at 1khz.
Distortion only 30db down== about .5% thd. Up and down slew rates very
non-symetrical...
but with tubes works very good
probably need one stage less
Old 18th October 2010, 07:05 PM   #5
Stee's Avatar
Default class A
other reason for failure might be the class
must be set "A"
or overlap with complete
Possible 6400 hybrid project. nigelwright7557 Solid State 0 29th April 2010 01:55 AM
Hybrid Srpp gianmaria Tubes / Valves 20 30th November 2009 04:59 PM
Project Hybrid tube-chipamp vthieu Chip Amps 0 3rd February 2008 07:40 AM
hybrid Amp project nitelite Solid State 2 17th May 2004 05:20 PM
6 channel hybrid amp project thoriated Solid State 0 19th December 2003 11:57 PM
Page generated in 0.07685 seconds (81.75% PHP - 18.25% MySQL) with 11 queries
