I posted this on AudioKarma with no luck of help
Hi All I just got a Son of Ampzilla, it was playing fine then it just started to buzz the right side and pegged the r.side meter? I had the cover off because when I got it, something was rattling around in there,I found a penny (the guy I got it from must have had kids) but after it started to buzz I found another one in there but it didnt look like it was shorting anything. Anyone have any ideas? I'm going to test the caps and go from there. Anyone have the bais points and settings? Thanks, Roy I was messing with the adjustment on the front of the meter to get it to 0. But I don't think that caused the problem. So far I tested the OPT all good (4) tested the drivers all good, tested the caps with a Blue esr meter all looked good. and just poked around and didnt see anything burned. When pluged in it pegs the r.side meter but i instantly turn off. Roy |
#2 |
Connect your meter to the output binding posts and check for DC on the output. Since the meter pegs I'm assuming there's DC. Do you have a schematic? If you do check the zener regulated supply. If that's bad the DC offset adjustment won't work and any offset in the front end will be amplified thru the amp. The main power supply is common to both channels so that is probably OK. You've checked the OPTs and they would blow fuses if they were bad. It might even be a bad/dirty DC offset trimmer, try moving it stop to stop to clean it up and then put it in the middle, turn it on and try adjusting for zero DC at the binding posts. The DC offset trimmer is the upper most trimmer on each board. The two towards the end of each driver PCB are for adjusting the VI limiters. The trimmer on the OPT PCB, the lower board, is for adjusting idle current. That is 30mv across one of the .2 emitter resistors. Make sure the input is shorted to gnd before adjusting anything. One caution using a ESR meter if you have a shorted capacitor it will look like a really good capacitor. Though shorting is not the usual failure mode for a capacitor it does happen.
Craig |
#3 |
I do have a schematic but don't know what and where the zener regulated supply is and how to test it. I'm a fast learner and know I can fix the amp with your and others help. Thanks!
The pic's of the meters was taken before it all went bad. One thing, is , this was the best sounding amp I ever had!!! and I only had it going for about an hour. Roy |
#4 |
BTW I'm at work now, but when I get home I'll do the testing.
Roy |
#5 |
Disconnect the Vu meter if you decide to re-power it again. The DC will blow it out. Are you sure you checked the correct channel outputs for shorts with your VOM? If yes then you probably lost a power supply rail. Don't connect any load (speaker or otherwise) until you get the DC on the output problem fixed. It should be less than .05 Volts DC.
If you've got one side working, you should be able to make comparative checks with your VOM and fix the other side. Sometimes you'll find semiconductors several stages back shorted and all will have to be replaced. |
#6 |
The left side of the amp will play fine. the right side is the bad side. I pulled each right side OPT and tested them with a transistor checker. all good. When you say power supply rail what is that?
#7 |
The power supply consists of two 'rails', one providing a positive voltage, the other a negative voltage with respect to ground. In addition, there is another supply riding on top of the rails which slightly boosts the voltage for the input and driver stage--this isn't often done on most amplifiers.
The supply voltages are plus and minus 45 volts DC for the output transistors and plus and minus 51.6 volts for the driver stage; there should be very little measurable AC ripple. Since you've got a big DC offset, I think there's a bias problem. I've got a SOA here to fix which has a bias problem in one channel--goes to Class C and audibly distorts. Haven't figured it out yet; I'm hoping it's not the bias IC which is hard to replace. In my unit the input different amplifier transistors are socketed; those should be checked and carefully replaced--there's a slight chance one could have loose/dirty connectors or be defective. |
#8 |
I did check 4 small transistor's in the socket's all ok and pulled the 2 pairs screwed to the board they checked ok also.
I really don't think I should plug it in for any longer then a second or 2 for fear of smoking the whole thing. Roy |
#9 |
You can check all four output rail voltages at the fuses on the power supply PCB, +45 and -45 VDC, on both left and right sides of the board. Be sure to check both sides of the fuse in case you don't know which is in or out. The input rail voltages, + and -51 VDC, can be checked at the 10 Ohm resistors right next to the double ceramic capacitors, .1uf, on each upper corner of the drive boards.
Craig |
#10 |
Can I pull the fuse's F001 -45v, F002 ch B, F003 ch B, F004 +45v then check the volt's or do they have to be in? What I read looks like out is fine (check both sides of fuse..) and if its higher or lower I will report what I find. I'm just gun shy to smoke the amp.
I'm still at work but will try this when I get home Roy |
| Son of Ampzilla problems | scsidude2 | Solid State | 42 | 19th June 2011 01:43 AM |
| Son of Ampzilla question | borabis | Solid State | 2 | 3rd October 2010 03:16 PM |
| My Son of Ampzilla | Dappel | Solid State | 12 | 18th December 2008 07:21 PM |
| Son of Ampzilla meters not lit? | orbsandoz | Solid State | 5 | 3rd November 2008 11:29 PM |
| G.A.S. Son of Ampzilla help needed | Cambe | Solid State | 1 | 25th September 2001 03:38 PM |
| Page generated in 0.12262 seconds (79.62% PHP - 20.38% MySQL) with 11 queries |
