Are you ready to face strong emotions?.. Dx Blame MKII and the Supercharged release! - Page 65 - diyAudio
Old 12th October 2012, 02:02 PM   #641
Vargas is correct.
A flat surface is better at transferring heat from one device to the other.
Why?
Because a non flat surface mating together with another flat surface will leave gaps in the metal to metal contact interface.
The "gaps" can be scratches or much worse. Those gaps if filled with air act as insulators (= high thermal resistivity).
Polishing both surfaces of the Thermal interface can reduce the "gaps" and will result in less thermal resistance.
The requirement for best thermal conductivity is reduction of the "gaps" to as near zero thickness as possible over the largest area as possible.
Why do we use thermal compound in the thermal interface?
To reduce the thermal resistivity of the "gaps". Thermal compound should have much better conductivity than air.
For this to be effective, the "gaps", all of them, must be completely full of thermal compound. In addition the metal to metal contact must still be made between the "gaps". That is why we should use the minimum of thermal compound to just fill the "gaps" completely, but not separate the metal interface from that necessary metal to metal contact across the biggest area possible.
If we introduce an electrical insulator between the two metal surfaces. Then we now have three layers to consider. The hot device to insulator interface, the thickness of the insulator and the insulator to cool device interface.
That three layer thermal path explains why a thermally filled metal to metal interface conducts heat better than any of the insulated interfaces.
Emissivity is a completely different subject.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 12th October 2012, 02:08 PM   #642
vargasmongo3435's Avatar
Send a message via Yahoo to vargasmongo3435
Thank you very much Andrew! I new some one can understand me, "my English is not perfect as a second language so is hard for me to get the right words lol, I appreciated you tip thanks.
vargasmongo3435
Old 12th October 2012, 02:16 PM   #643
But a word, or several, of warning.
A flat scratched surface may be better than a polished version of a non flat surface.
It depends on how much of "non-flatness" exists in the polished version compared to the (alleged) flatness of the scratched surface. The polishing can be the process that introduces the non-flatness from the previously flat scratched surface.
regards Andrew T.
Old 12th October 2012, 11:59 PM   #644
destroyer X's Avatar
Default Because it is not easy to obtain a flat surface and not easy to have it polished
then we use silicon grease, the thermal compound fill all the gaps resulting in a better heat transference... flat or not that flat.... polished or not polished...then you gonna have much better results when you compared with the transistor attached to the heatsink without any kind of thermal compound.
In other words dear Juan...having polished surface or not having a polished surface...always use thermal compound, and to avoid air bubbles inside, apply a lot and let the excess appear around the component after you tight your screws... remove the excess with cotton tissue, clean the white marks (stains from your silicon grease) with a cloth dampened in Kerozene (Querozene) or aviation fuel...or any kind of petrol solvent and be happy.
regards,
Carlos
Full throotle amplifier manufacturing; https://www.youtube.com/watch?v=iEXaSSlMEBg
Old 13th October 2012, 02:17 PM   #645
Vostro is offline Vostro  South Africa
Vostro's Avatar
Just to clarify when I spoke about ripple matt black, I was referring to the
greater area of the heatsink and not the contact area,
The contact surface must be flat, as AndrewT stated, flat trumps shiny smooth.
Old 13th October 2012, 04:14 PM   #646
and flat shiny smooth trumps flat matt smooth. Matt being very fine scatches.
regards Andrew T.
Old 13th October 2012, 04:40 PM   #647
On the other hand for bolted interfaces the thermal impedance increases significantly with distance from the fasteners, yes thermal fillers help mitigate this problem.
If you imagine a curved TO-3 package such that the center point touched the heat-sink prior to the mounting ears, then when the TO-3 is fastened down flat, the center area will have more pressure (less thermal impedance) than it would having it started out flat.
Similarly scratched interfaces surfaces with the scratches being perpendicular to each other when fastened together will cause the crossing of the scratches to form lots of very good thermal interface points kind of like local welding.
-Antonio
Old 13th October 2012, 04:51 PM   #648
Originally Posted by magnoman View Post
...................Similarly scratched interfaces surfaces.............when fastened together will cause the crossing of the scratches to form lots of very good thermal interface points kind of like local welding.............
I don't know, but the extra pressure from tighter fastened bolts does seem to improve the thermal flow. That could be due to deformation of the metal to metal points becoming wider areas under the extreme pressure of point to point contact.
But that deformation of the points must not be allowed to change the shape of the flat surface. This is may be why clamping gives good results, rather than bolting.
The dual bolts of the big Sankens and the To3 packages may also explain why they perform well. They are closer to being "clamped" rather than a single bolt that is way off centre from the hot spot under the hot junction.
regards Andrew T.
Old 13th October 2012, 05:02 PM   #649
Seems to me clamping is a way to increase the area under pressure, same concept.
Pressure relationship does require deformation but this can be on the microscopic level hence the improvement with scratches.
-Antonio
Old 13th October 2012, 08:07 PM   #650
Vostro's Avatar
Think of heat energy as being similar to visible light energy,
metalic shiny surface will refelct it and absobtion isnt optimal,
Here surface area and mounting pressure are important, but the overall colour of the heatsink is also a big factor.
As for the mating surfaces, these will Never be 'flat' no matter how good you are at diy, thermal paste works a dream cure for this,
Ill even say that very minor scratches on a flat surface will have minimal inpact, if proper amount of paste vs mounting pressure is adhered to.
Ill use a matt black rippled fin heatsink over a shiny gold or shiny anodized heatsink.
" Shiny gold anodised heatsinks might look great (if you like that sort of thing), but are hopeless at radiating heat. It's no accident that the radiator in a car, or the condenser on the back of a refrigerator is matte black - not chrome plated and shiny. Matte black heatsinks are the best for radiation"
ESP - Heatsink design and transistor mounting
DX Blame Group Buy Rudi_Ratlos Group Buys 412 19th August 2012 05:00 PM
Dx Blame ES .... based into the Blameless, i am trying a new amplifier destroyer X Solid State 1826 12th February 2011 08:11 AM
Dx Blame MKII, an obvious evolution from the Dx Blame ES/ST destroyer X Solid State 4 25th September 2010 07:41 PM
Tuning the DX Blame amplifiers, for newbies... smartx21 Solid State 3 15th May 2010 05:56 PM
Copyright 1999-2017 diyAudio
