Are you ready to face strong emotions?.. Dx Blame MKII and the Supercharged release! - Page 3 - diyAudio
Old 16th October 2010, 11:46 AM   #21
Bonsai is offline Bonsai  Europe
Bonsai's Avatar
I want you to learn of these things my friend:-
Decorum. Restraint. Dignified Enjoyment. Honour. Tolerance. Community.
This is the way of the East.
Greetings from this wonderful island, Japan, on this beautiful late summers evening, as a sip my warm sake . . .
bonsai
Amplifier Design and Construction for MUSIC! http://hifisonix.com/
Old 16th October 2010, 11:47 AM   #22
destroyer X's Avatar
Default I only follow suggestions after i test them Andrew... also
i am moved by motivations...my customers (DIY) are my targed...they ask and i move....In the reality, brazilian friends asked me..that's what moved me to change things, not your suggestions.
I use to follow suggestions from my mind... sometimes the rusted machine works.
But go dreaming was you the reason why that moved me... only by magic as i used not to read you..so..could not see your suggestions.... believe was you...if this feeds your soul.
From time to time i go reading you..to check your mood if you're in the 5 percent positive moments.
regards,
Carlos
Full throotle amplifier manufacturing; https://www.youtube.com/watch?v=iEXaSSlMEBg, Sample Dx Classic https://www.youtube.com/watch?v=fVvFrwl92RU
Old 16th October 2010, 11:57 AM   #23
Default Boys.... i am applying some torture on Blame MKII.
But really i am lazy these days after surgery...i feel some small pains when moving too much.... so...i will not connect several supplies in parallel (Dc out in parallel)... because of that, i have no power from the supply to feed 2.5 ohms loads or even a little bit less than that... reason why i made test only to 3.0 ohms (discounting my meter cable errors during measurement and parallel resistances behind the huge speaker).
It seems safe to 3.0 ohms.... i am really not sure if will survive to 2.5 ohms or less...so...because lazy...i will specify the unit to 3 ohms minimum load...... it is reasonable...others can try lower impedances....well.... make it under your own risk..i do not believe in simulators datasheet or graphics.... simulator said OK!....but not testing real life i do not believe and i cannot guarantee good results.
YouTube - Torture on Blame MKII continues.,.200W - 3 ohms
regards,
Carlos
Old 16th October 2010, 12:55 PM   #24
norazmi is offline norazmi  Malaysia
okay Uncle Charlie, ill build a troyan until this board will release ill build this one too.
ill go to troyan discussion board to see the details to build troyan, ill try to finish troyan as fast as i can with your guide.
Azmi.
Old 16th October 2010, 01:08 PM   #25
Default Board was not tested Azmi... but the circuit is OK!
I will forward you some small modifications as soon as you start to build and publish some pictures.
I am not talking about the chance to have oscilations.... but the change to have something missed there... both things are possible, despite the one made the board, Alexmm, is very good...but we..humans, we fail.
regards,
Carlos
Old 16th October 2010, 06:21 PM   #26
aight uncle, understand, psttttt.. take ur time to rest okay...
regards.
Azmi
Old 16th October 2010, 08:30 PM   #27
Default Thank you Azmi, by your understanding
regards,
Carlos
Old 16th October 2010, 10:24 PM   #28
Default Boards are ready to go...layout is ready..also tests are doing fine
So, no troubles to the release in December, 24th.
I had to take some decisions:
First was one board to all models.... Dx Blame ES/ST, Dx Blame MKII and Dx Blame MKII Supercharged.
Second, silk screen forced me to use a standard transistor to all models, so, at the silk screen we have 2N5401 and 2N5551 indications...but people can use BC546/556 (suggested) in the place of the high voltage ones, just inverting the way they will go to the board.... silk screen indicates 2N5401 and 2N5551, and these ones works too...it will be up to you folks, the ones to use.
Dx Blame ES/ST and Dx Blame MKII uses 35 volts (42 volts maximum)..the Dx Blame MKII Supercharged will use higher voltage...maybe 55 or 63..i am still thinking about and testing options.
Almost all parts will have part numbers and also their values printed inside resistance rectangles (covered by the resistance after assembled), to make it easy and faster to assemble.... some parts are different to each model, and these ones, the different ones, will have part identification numbers and no values....values will be obtained from a chart that will be published the same day i will publish schematics, layout and the chart of part's substitution values.
I am showing you just the upper part.... i am very happy with this board..finally i could have a board that matches, entirelly, my needs... well... this is a natural progression.... i was waiting 7 years to have it my way..finally this one is "my way".
This one is 100 percent approved, i had not to negotiate, Mitchel made my way..... a matter of coincidence..... it is his way too... maybe cause we are both Brazilians..no troubles...he made with pleasure and had not to make violence with himself.
regards,
Carlos
Old 17th October 2010, 07:10 AM   #29
Default A needed tribute to Todd Johson, our TAJ, will be printed into the board
As all further layout developments started from his excellent work...so, despite some upgrades made, he deserves to be pointed as the pionner in this layout style.
regards,
Carlos
Old 17th October 2010, 09:16 AM   #30
re post 28,
notice how close the supply rails come to each other at the collectors of Q9 & Q10.
This is where the HF decoupling should be placed. There is space between the transistors and traces on the top (or links if single sided) will pass across the other traces. Or use the empty part of the PCB under the legs of the bd139 Vbe multiplier for a bottom side trace.
The biggest problem left is the long distance ~90mm to the nearest point on the Power Ground.
regards Andrew T.
Sent from my desktop computer using a keyboard
DX Blame Group Buy Rudi_Ratlos Group Buys 412 19th August 2012 04:00 PM
Dx Blame ES .... based into the Blameless, i am trying a new amplifier destroyer X Solid State 1826 12th February 2011 07:11 AM
Dx Blame MKII, an obvious evolution from the Dx Blame ES/ST destroyer X Solid State 4 25th September 2010 06:41 PM
Tuning the DX Blame amplifiers, for newbies... smartx21 Solid State 3 15th May 2010 04:56 PM
Copyright 1999-2017 diyAudio
