Are you ready to face strong emotions?.. Dx Blame MKII and the Supercharged release!
Old 23rd October 2010, 10:23 AM   #41
post28 shows Q9 & Q10.
these happen to be located right at the two ends of the Power supply rails. These are the closest that the supply rails come together on the PCB.
Here is where the HF decoupling should be fitted. This is to minimise the length of track/trace from the +ve output device collector to the +ve rail HF decoupling to the -ve HF decoupling to the -ve device collector. This route must be short to keep inductance down. If inductance in this route is allowed to rise then the HF decoupling cannot pass HF transients and becomes worthless.
The centre point of the LF decoupling and the centre point of the HF decoupling are joined together to become the PCB Power Ground. Unfortunately the main Ground is ~90mm away from the HF decoupling centre point. That is brought about by the enormous spacing between the +ve supply rail trace and the -ve supply rail trace. These two rails must be located right next to each other to minimise the radiated effects the half wave rectified currents have on the rest of the low level circuitry.
regards Andrew T.
Old 23rd October 2010, 07:26 PM   #42
taj is offline taj  Canada
taj's Avatar
Okay. I think I understand. That would be tough to implement in this scenario without a double-sided board.
..Todd
Old 23rd October 2010, 07:59 PM   #43
destroyer X is offline destroyer X  Brazil
destroyer X's Avatar
Default Wanna be happy?
Build a Dx Blame or build one alike that:
YouTube - GolfJet Jet Turbine Powered Golf Cart
both will provide you fun and strong emotions!
regards,
Carlos
Dx unbeatable amplifiers; https://www.youtube.com/watch?v=u4tGBiqMnzQ
Old 28th October 2010, 12:25 AM   #44
Default Earlier release for the Supercharged soon...the next days
YouTube - Supercharged earlier release...soon
regards,
Carlos
Old 29th October 2010, 07:43 AM   #45
Default We are working in the details, discussing sizes and shapes
We are not sleeping..the "Corporation" is working full time to achieve better and better quality into boards, layout and schematic.
Soon you gonna see the result..now we are reducing supply size, because our amplifier is suggested to use two separated supplies...also can use a single one too..but when using two supplies the performance is better, but also the room needed to two transformer and two supply boards is huge..so..we are reducing all we can.
regards,
Carlos
Old 29th October 2010, 01:52 PM   #46
Default Dear Friends...here you have the Dx Blame MKII Supercharged
and the board.
I will soon explain you in details..but you can be watching the schematic and the board and you will understand the basic things.
First.......... schematic is the same..amplifier is the same... sonics is the same..quality is the same..distortion is the same.... power is different
Second....the Supercharged is a 200 watts rms / 4 ohms power amplifier
third...the Dx Blame MKII is a 180 watts amplifier to 3 ohms loads....so....will be good to difficult and low impedance speakers.
You see some parts in the board without value..these are the parts will be replaced depending the model you will assemble.
The board is good for:
Dx Blame ES
Dx Blame ST
Dx Blame MKII
Have only to replace some parts...transistors are the same to all models..yes...all models.
The first three models use 35 o 42 volts supplies
Soon you gonna have more details..also soon you gonna have a group buy to be organized by Mitchel that promissed to do that.
Soon you gonna have black and white layout to allow you to etch your boards at home..not only to Toner transference method, but also to the photographic method to layout image transference to copper boards.
Boards will go with xerox showing part numbers....pdf also will be published...a chart will explain the different parts that belongs to each model in special
So... we are starting to release informations....i will produce texts, also videos explaining the differences..but schematic and board shows things clear.
regards,
Carlos
File Type: pdf Dx Blame MKII last revision..final one.pdf (40.9 KB, 537 views)
Old 29th October 2010, 05:37 PM   #47
A square is offline A square  Australia
A square's Avatar
Send a message via Yahoo to A square
hello sir ...
very nice amp ...
i love to make it....
thanx .....
jon
Old 29th October 2010, 05:46 PM   #48
doggy is offline doggy  Canada
doggy's Avatar
I am also waiting to obtain some DX boards, before I order parts-there is a lot of reading in the DX-ES Blame thread.
For amplifier theory, what books are available that explains vbe and basic amplifier circuits? Soft cover is fine, suitable for reading when waiting to catch a flight!
Old 29th October 2010, 07:10 PM   #49
Default I will love to have you building my amplifiers ASquare
Dear Doggy, books really do not explain such details...forum people may help.... i can do it if you post or mail me specific questions alike; what is VBE, what is the normal VBE, What VBE does.
I will try to find some books for you... send me an email to me to capture your home email adress... then i will be able to send you some tips and tricks, links and so on.
nanabrother@hotmail.com
regards,
Carlos
Old 29th October 2010, 08:23 PM   #50
Mitchel is offline Mitchel  Brazil
Mitchel's Avatar
Hello everyone!
This is the link for the groupbuy:
http://www.diyaudio.com/forums/group...-interest.html
We need to know if there is enogh interest in those PCBs, so please let us know by posting on that thread.
Are you ready to face strong emotions?.. Dx Blame MKII and the Supercharged release!Hide this!Advertise here!
DX Blame Group Buy Rudi_Ratlos Group Buys 412 19th August 2012 05:00 PM
Dx Blame ES .... based into the Blameless, i am trying a new amplifier destroyer X Solid State 1826 12th February 2011 08:11 AM
Dx Blame MKII, an obvious evolution from the Dx Blame ES/ST destroyer X Solid State 4 25th September 2010 07:41 PM
Tuning the DX Blame amplifiers, for newbies... smartx21 Solid State 3 15th May 2010 05:56 PM
Copyright ©1999-2017 diyAudio
