Are you ready to face strong emotions?.. Dx Blame MKII and the Supercharged release!
Old 31st January 2011, 03:42 AM   #411
Luke352 is offline Luke352  Australia
Send a message via MSN to Luke352
Looks nice.
Does anyone have a link for the enameled wire for making the inductor, I can't find the stuff anywhere on Digikey and I've tried searching other suppliers without luck.
Old 31st January 2011, 03:47 AM   #412
destroyer X is offline destroyer X  Brazil
destroyer X's Avatar
Default While you are searching for the enameled wire... use telefone wire
Yes,...the one covered by plastic...works too.
regards,
Carlos
Dx unbeatable amplifiers; https://www.youtube.com/watch?v=u4tGBiqMnzQ
Old 31st January 2011, 03:49 AM   #413
You need some inductance there....and any insulated wire, if coiled, can do the job.
regards,
Carlos
Old 31st January 2011, 06:21 AM   #414
niss_man is offline niss_man  Australia
Originally Posted by Luke352 View Post
Looks nice.
Hi Luke
Your in Brisbane right. I got mine from RS Components.
RS Australia | World Leading Distributor of Electronics, Electromechanical and Industrial Components Your search for enamelled wire
Their trade desk is at Archerfield or can order online. Or alternatively you can come round my place and I can give you some I have spare. I may be out of the way though situated between Beaudesert and Browns Plains.
Simon
Old 31st January 2011, 07:04 PM   #415
Default Dx Blame MKIII was produced, assembled and tested
Brazilians asked a higher power version able to operate 2 ohms.
Now 2 beta testers are building....it is the Supercharged retuned....so, not a new amplifier....it is the same having 6 resistances substituted and more output pairs.
regards,
Carlos
Old 31st January 2011, 08:08 PM   #416
Default These are my private reserve of boards..i am still building to my family
I have already build 3 units...and there are others to come.
These are my own boards.... special reserve.
regards,
Carlos
Old 7th February 2011, 10:19 AM   #417
Default This is a threshold of clipping indicator...it indicates already clipped voltage
that will appear at your Supercharged output when you overdrive it.
Led will have normal brigthness when you reach 156 watts RMS over 8 ohms or twice of that at 4 ohms...the distortion will be around 1 percent when you perceive it on.
Simple, fast to produce and cheap...can be connected into your output terminals or even inside a speaker.
So, the very good idea is to keep it off... when you have clipping you will have high frequency harmonics that may destroy your tweeters..so... adjust your listening level keeping that LED off.
This was made to the Supercharged..when powered by 55 volts supplies..do not use it with higher power amplifiers or you may damage the LED because of overcurrent...works to the Supercharged..was tested...passed!
regards,
Carlos
Old 7th February 2011, 11:16 AM   #418
Default To the ones understand latine languages..here you have a video
explaining more details:
YouTube - Clipping threshold indicator
regards,
Carlos
Old 8th February 2011, 11:50 AM   #419
Originally Posted by niss_man View Post
Hi Luke
Simon
Thanks, I ended up dropping into the local Jaycar yesterday and they had some, I hadn't checked earlier because it didn't come up in there online search. Goes to show sometimes it pays to visit.
Old 8th February 2011, 09:30 PM   #420
Default Boys, please, use heatsinks to both VAS transistors and use
Big transistors in this position.... something alike MJE15032 is fine.
If you want to push above the limits you can increase the Supercharged sensitivity replacing R7.....try 390 ohms.
Was tested full power over 4 ohms speakers, both channels operating into clipping.
Video about this same subject:
http://www.youtube.com/watch?v=LFGn1BFcJLE
regards,
Carlos
URL=http://img543.imageshack.us/i/stillwaitingknobsarrive.jpg/]Click the image to open in full size.[/URL]
File Type: jpg Testing both channels driven at 4 ohms.jpg (290.0 KB, 88 views)
Are you ready to face strong emotions?.. Dx Blame MKII and the Supercharged release!Hide this!Advertise here!
DX Blame Group Buy Rudi_Ratlos Group Buys 412 19th August 2012 05:00 PM
Dx Blame ES .... based into the Blameless, i am trying a new amplifier destroyer X Solid State 1826 12th February 2011 08:11 AM
Dx Blame MKII, an obvious evolution from the Dx Blame ES/ST destroyer X Solid State 4 25th September 2010 07:41 PM
Tuning the DX Blame amplifiers, for newbies... smartx21 Solid State 3 15th May 2010 05:56 PM
