Old 12th October 2010, 02:35 AM   #1
AAK is offline AAK  United States
Default SymAsym - "The Sequel", AAK's Rev_1.4 PCB Builders Thread
Welcome! This thread is for all those who bought my Rev_1.4 PCB based on Mike Bittner's SymAsym – "The Sequel” circuit design. Of course everybody is welcomed, and if you have something to add by all means feel free to jump in.
Attached is a pdf document with step-by-step instructions to help assemble my PCB.
I've also attached the latest BOM, schematics for the amplifier and PS section and some pictures that should help with the assembly process.
To provide some background for those unfamiliar with MikeB's SymAsym - The Sequel design, here's the link to his thread.
Symasym - the sequel
Here's the thread that I started describing my original Rev_1.3 PCB design based on MikeB's design.
My new SymAsym PCB design Rev_1.3
Note that on the PCB there's a couple labeling mistakes, check page 2 bullets 1&3 of the Assembly Instructions Document for instructions.
I still have a few boards left for those interested.
Al
File Type: pdf STS100_Rev_1.4_Assembly_Instructions.pdf (110.8 KB, 630 views)
Love when you can, Cry when you have to, be who you must, that's part of the plan.
Old 12th October 2010, 03:09 AM   #2
I've attached two real world THD plots of the amp driving an 8 ohm load at 100 watts, and a 4 ohm load at 180 watts at 1khz. In each pic the THD plot of the input signal is on top, and the amplifiers output THD on the bottom.
Old 13th October 2010, 09:37 AM   #3
I`m waiting for boards an plan to build an amp. I have two transformers. They are both 2x 33Vac/ 600VA. From what I understand using one of them might be enough for a two channel amp?
What C/W - value do I need for the heatsink, each channel, if the psu gives me about 45-46 Vdc?
Old 13th October 2010, 10:43 AM   #4
Default Voltage rating C24
Hi everybody,
I omitted including the C24 caps my last order at mousers.
How critical is the voltage rating of C24 as I would have some 470/16 in a drawer ?
TIA,
Max
Old 13th October 2010, 11:07 AM   #5
AndrewT is online now AndrewT  Scotland
in normal operation C24 has virtually no AC voltage across and virtually no DC voltage across it.
In failure mode the cap can see either rail voltage across it.
To prevent damage to the capacitor in failure mode one can add a diode across it's terminals to protect it from reverse bias voltage.
It can also be protected against excessive forward bias voltage by adding a second diode in reverse direction.
Some use two diodes in series in both directions so that at +-1Vpk the diodes do not pass, but they limit the worst case cap voltage to <2Vpk.
These diodes can usually be placed on the bottom side of the PCB and easier if you don't clip off the cap leads until after the diodes are soldered in place.
If the cap is diode protected you can use any voltage from 5V and upwards.
Your 470uF 16V is perfect, just add the inverse parallel diodes.
Old 13th October 2010, 11:20 AM   #6
Hi Andrew,
thanks a lot for your kind answer.
So, If I get you right it doesn't really matter as the 470/25 as mentionned in the BOM would blow anyway in case of rail voltage, right ?
Maybe you could get back to me per PM as I don't want to pollute this very fresh building thread.
Max
Old 13th October 2010, 06:25 PM   #7
pchw is offline pchw  United States
Default 2 nice posts from AndrewT in the GB thread
is bd139 important to the performance of the amplifier?
I would use any low current, medium gain, medium fT, To126 NPN for the Vbe multiplier.
I would even consider and have used a To92 glued to the output transistor or the heatsink.
R34=499r may be a bit high. You might have to reduce slightly to 390r, or 430r to allow output bias to be set.
I think the 35mV bias voltage is the sum across both emitter resistors, i.e. 17.5mVre.
R36 to it's maximum resistance for initial setting up.
This ensures least or nil output bias current.
The ratio of R35:R34 is ~4:1. I tend to use from 5:1 to 6:1 to ensure sufficient range of adjustability to suit a wide range of different transistor Vbe.
eg if Q17 has Vbe ~0.55V then the maximum bias voltage is ~2.75V
If the output transistors have Vbe ~0.65V then one needs ~2.65V to get a Vre=25mV. That leaves only 100mV spare for tolerances. But this is worst case design, not for a fully specified design. 499r should work, but will nearest E24 value of 510r work?
Rudi also pointed out another variation in
SymAsym - The Sequel, AAK's PCB GB
- Fred -
Last edited by pchw; 13th October 2010 at 06:28 PM. Reason: Used the wrong quote tag
Old 13th October 2010, 09:03 PM   #8
the schematic that Rudi found and posted is wrong. See my later comment.
Old 14th October 2010, 06:18 PM   #9
poler is offline poler  United States
I have what is probably a noob question but do I need LSK170 A, B or C? Thank you.
Old 14th October 2010, 10:52 PM   #10
LSK170B is equivalent to 2sk170BL
Symasym 5.3 "AAK model" builder's thread MBK Solid State 719 23rd March 2013 10:52 AM
My new SymAsym PCB design Rev_1.3 AAK Solid State 143 24th August 2012 10:14 PM
SymAsym - "The Sequel", AAK's PCB Builders Thread AAK Solid State 219 3rd June 2012 04:21 PM
SymAsym - The Sequel, AAK's PCB GB Piersma Group Buys 226 24th February 2011 07:33 PM
Copyright ©1999-2013 diyAudio
