#21 |
Hi Fred,
Don't worry about the voltage not being between 7-8V. Using the circuit that I provided in the Assembly Instructions Document find the closest match. Your jfets with Idss ranging from 6ma to 10ma should work fine. Regards, Al
Love when you can, Cry when you have to, be who you must, that's part of the plan. Last edited by AAK; 19th October 2010 at 01:54 AM. |
#22 |
Thanks you, Al !!
- Fred - |
#23 |
Hi Everybody,
I took advantage of Al's offer on matched transistores as probably others in the GB. Now I find myself with 8 2N5551 - 2 matched pairs and 4 bulk in total , but I am unsure on where to use the matched pairs. Should I use them for Q3,Q4 or rather for Q18,Q19 ? Maybe someone with more insight concerning the schematic could help me out here ? Thanks in advance, Max |
#24 |
Matching problem solved..
Thanks! |
#25 |
Hi Al!
Just wanted to let you know, that both channels are fired up and playing the sweet sound of Tina Dico's "In The Red" I followed your excellent assembly instructions to the letter, and everything went well. I even hooked up a light bulb limiter as Andrew T suggested in another thread. Power supply was fine, and measured 6mv of DC on left channel, and 15mv on the right on. I might look into that later. Biasing was a little bit scary. Even though you stated that it would take several turns to get the bias going I got a bit spooked after the 6 or 7th turn as nothing happened. I started to wonder if I was measuring the right pins, was my meter broken, was I cranking bias like a madman into the poor OT's? :-D Double checked everything and eventually the bias came up. I had about 1,5mv of drift on both channels. I really like all the small LEDs It makes the circuit board seem very much alive :-) A big thank you Al for organizing all this, and thanks to Mike Bittner, for designing the amp. I have yet to hear it on anything than my bench speakers. I am very much looking forward to that.
Perception is reality, not truth. |
#26 | |
...truth seeker...
It plays today.
...call me Ed...Special Ed... EnABL kit http://www.diyaudio.com/forums/swap-meet/119852-enabl-kit.html DCB1 parts http://www.diyaudio.com/forums/swap-...ml#post2361098 |
#27 |
Well, I don't want anybody having heart attack because of me.
That's great Lars that your amps are working. Good job! Al
Love when you can, Cry when you have to, be who you must, that's part of the plan. |
#28 |
setting up a minimum of 0.1mA of bias will make this set point very susceptible to small variations in Vbe of the transistors in the multiplier and output stage. I think a better way is to describe how to measure the multiplier output voltage. This varies continuously as the Vr is adjusted and gives a good indicator of how the setting is progressing even when the Ib is still virtually zero milliAmperes.
regards Andrew T. Last edited by AndrewT; 25th October 2010 at 11:53 AM. |
#29 |
Actually I meant selecting a value for R34 so that the voltage across the OS emitters is approx. 0.1V with R36 (Vr) initially set to its highest setting. That way if it's not 0.1V a single turn or two of R36 will begin to adjust the output current without the anxiety of waiting seven or more turns.
#30 |
Hi Everybody,
just to let you know that we managed to finish our 4 boards last night. They powered up smoothly and measure as follows with the 100 Ohm-resistor on the same PS-board: V+ V- Offset PCB1 2,99 2,52 5,5mV PCB2 3,00 2,52 4,8mV PCB3 2,99 2,52 5,2mV PCB4 2,98 2,51 7,2mV I am not sure if the imbalance on the 2 PS-rails is "normal", could Al confirm maybe ? Furthermore, should I be worried of the one amp having an higher offset than the others ? We did not go as far as setting the bias as the heatsinks are not drilled yet. Cheers, Max P.S.: Al, referring to R44 & 45 did you have the time to do some testing ? I assume I can go ahead with the bias setting ?
| Symasym 5.3 "AAK model" builder's thread | MBK | Solid State | 704 | Today 08:54 AM |
| SymAsym - "The Sequel", AAK's PCB Builders Thread | AAK | Solid State | 217 | Yesterday 12:42 PM |
| My new SymAsym PCB design Rev_1.3 | AAK | Solid State | 142 | 29th October 2011 08:22 AM |
| SymAsym - The Sequel, AAK's PCB GB | Piersma | Group Buys | 226 | 24th February 2011 07:33 PM |
| Page generated in 0.09904 seconds (70.38% PHP - 29.62% MySQL) with 11 queries |
