Old 4th November 2011, 02:28 PM   #101
The amp is running fine for a couple of days now, getting pretty warm though.
No turn-on thumb or whatsoever.
The only annoying thing is the crackling sound from the speakers as the caps of the amp discharge on turn of.
I used the search function but could not find some having build a simple relay-solution for shorting the outputs on turn-off.
I don't wat to go for the Velleman solution as I need 4 of them and the price tag is a bit high, at least for me.
Any hints ?
Old 6th November 2011, 02:11 PM   #102
AndrewT is online now AndrewT  Scotland
Start with a manual input mute and see if that makes a difference at shutdown.
Just short all the signal inputs to their respective signal returns. Power ON, warm it up. Power OFF. Any improvement?
regards Andrew T.
Old 12th November 2011, 02:32 PM   #103
...truth seeker...
Ed LaFontaine's Avatar
Location: where the Appalachians rise from the Blue Grass
Al,
The package with boards and other goodies arrived today. Thanks
Old 18th March 2012, 09:34 PM   #104
Where is the BOM for this board?
Any technology sufficiently advanced is indistinguishable from magic
Old 19th March 2012, 12:15 AM   #105
...truth seeker...
Latest one I have found:
http://www.diyaudio.com/forums/attac...ev_1.3_bom.pdf
Old 19th March 2012, 12:24 AM   #106
pinkmouse's Avatar
Here you go:
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 19th March 2012, 01:27 PM   #107
AAK is online now AAK  United States
Hey Guys,
Al's attached BOM is the correct one for Rev_1.4. Ed, the BOM you attached is for Rev_1.3.
Best Regards,
Al
Love when you can, Cry when you have to, be who you must, that's part of the plan.
Old 26th May 2012, 02:51 AM   #108
SteveA is offline SteveA  United States
Default Version 1.3 questions
I bought 6 (and rec'd 12) of the version 1.3 amp quite some time ago. I have now returned to the project having completed all the boards(except for output transistors on 4) I have tested the 8 boards which are complete (complete with dim bulb tester).
The bad news is 3 failed the smoke test. The somewhat better news is that the other 5 all passed the smoke test (all 8 board display the correct rail voltages of +/- 52.3 V which is inline with noload conditions for a 35-0-35 transformer I'm using). Testing the 5 boards with the 100R safety resister inplace I measured voltage drops accross this resistor ranging from 1.4V tp 1.7V. The assembly manual for version 1.4 indicates this drop should be 2.5-3.5V. Should the voltage drop for version 1.3 be the same or, if not, what should it be (and do I have an issue with the 5 smoke free boards)?
Thanks,
SteveA
Symasym 5.3 "AAK model" builder's thread MBK Solid State 704 Today 08:54 AM
SymAsym - "The Sequel", AAK's PCB Builders Thread AAK Solid State 217 Yesterday 12:42 PM
My new SymAsym PCB design Rev_1.3 AAK Solid State 142 29th October 2011 08:22 AM
SymAsym - The Sequel, AAK's PCB GB Piersma Group Buys 226 24th February 2011 07:33 PM
Page generated in 0.09200 seconds (70.50% PHP - 29.50% MySQL) with 11 queries
