Greetings:
I recently purchased a B&K AV5000 in need of repair. This amplifier is rated at 125 watts per channel into 8 ohms and has 5 channels. What I'd like to do while I'm repairing it, is bridge pairs of channels to give more power into two channels for stereo use. While I've repaired equipment as a hobby for nearly 25 years, I've never designed circuits so hence don't understand how I would go about bridging this unit. I'd rather not fry stuff experimenting, so I thought it might not hurt to ask if some of you folks with expertise would be willing to help. I've attached the schematic for reference. I'm looking for the best solution that would also keep it stable. For reference, per reviews, B&K did a very nice job on this amp. It's biased fairly high so it runs hot. I've read it tends to have the nice, smooth midrange that fets are so good at when the bias is turned up. The price was right and I figured it might make a nice two channel amp. I'd just prefer to have more bottom-end grunt if I can get it. Any help would be much appreciated! Thanks in advance, Steve B&K AV5000 Schematic.jpg
"If I had my life to live over again, I would have made a rule to read some poetry and listen to some music at least once a week." - Charles Darwin Last edited by Apogee; 2nd October 2010 at 12:05 AM. |
#2 |
Use bridge adapter, or use " Bridge adapter schematic " & type on the Google!
Regards zeoN_Rider |
#3 |
Thank you zeonrider for the info.
I was hoping I could just tap part of the input circuit from one and feed to the other to make it work. Some amplifiers have a bridging switch to combine channels and I was hoping for a similar solution. I would rather not run the signal through an inverting stage if I don't have to. Can I just run a balanced preamp and take + and - from the balanced output, run each to a separate channel input of the amplifer, then just take the speaker output from each of the positive speaker terminals? Is it really that simple? Would it be a problem if both input grounds were common? Any help is much appreciated! Regards, Steve
"If I had my life to live over again, I would have made a rule to read some poetry and listen to some music at least once a week." - Charles Darwin Last edited by Apogee; 2nd October 2010 at 01:20 AM. |
#4 |
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
From a quick look at your schematic, I have a question. Does this amp have a balanced input? It looks as though both signal polarities are fed to CON1 at the left side. If this is the case it will be fairly simple to arrange it to be bridged.
I think ideas are what you want to get rid of. I don't really like songs with ideas. - Leonard Cohen |
#5 |
Hi abraxalito,
No, it doesn't have balanced inputs. They are all RCA jacks. Also, any idea what the function of J1 would be? Thanks, Steve
"If I had my life to live over again, I would have made a rule to read some poetry and listen to some music at least once a week." - Charles Darwin Last edited by Apogee; 2nd October 2010 at 03:33 AM. |
#6 |
I think then that your best solution is the one you've already suggested - take the + and - outputs from a balanced o/p of your pre. The speakers are connected, as you say, between the two positive terminals. Bear in mind that when operating in bridged mode, the speaker impedance the amp sees is halved - you said it already runs hot. It will surely run hotter when running in bridged. Lateral FETs aren't the best choice in such a configuration but I'm sure it will work.
#7 |
Ok,
I'll give it a go and see what happens. Thank you for the help! Kind regards, Steve
"If I had my life to live over again, I would have made a rule to read some poetry and listen to some music at least once a week." - Charles Darwin |
#8 |
#9 |
I did notice that and it was why I asked about how to bridge in the first place. I should have been more clear in my question.
Where would that be connected to on the other channel? The input? Since it's past the input stage, I thought it would be too hot to feed the adjacent channel input. Figured there would be a BR IN or something like that to connect it to and I didn't see that. Any idea? The amp is due to arrive on Tuesday so I'll have a better idea after I physically see it. Thanks, Steve
"If I had my life to live over again, I would have made a rule to read some poetry and listen to some music at least once a week." - Charles Darwin Last edited by Apogee; 2nd October 2010 at 02:41 PM. |
#10 |
Please tell us how your amp turned out? I'm a bit curious on what you did and if it worked or not.
I've just ordered a B&K Video 5 and I'm hoping it's in good working order with no need of repair. |
| Adcom GFA-545 II bridging question | dhoover | Solid State | 4 | 30th August 2006 10:17 PM |
| Help needed with DIY chill amp II | Spasticteapot | Chip Amps | 1 | 14th March 2006 12:14 AM |
| Bridging stk 4192 II chip | rs1026 | Chip Amps | 0 | 30th August 2004 01:41 PM |
| Adcom Schematic Needed Gfa-545 Ii | Mattyo5 | Solid State | 8 | 12th June 2003 03:56 PM |
| Page generated in 0.09987 seconds (80.91% PHP - 19.09% MySQL) with 11 queries |
