Old 10th September 2003, 07:21 AM   #51
Default New method of current-drive loudspeaker
In this patent for current-drive authors used bridge of one amplifier as voltage-source and other - as current-source. Patent in Djvu-format in Russian with abstract in English.
Old 31st October 2011, 04:37 PM   #52
Are there any DIY kits or plans for a decent (low distortion, very low high-order HD or IMD) current source amp?
Old 31st October 2011, 10:12 PM   #53
sbrads is offline sbrads  United Kingdom
I would have thought an 8 year old abandoned thread would be a good indicator of there being no plans.
I briefly tried high impedance drive on a 3-way once - it sounded awful.
Old 31st October 2011, 11:27 PM   #54
Ian Finch's Avatar
Hi 454Casull
Your fellow Canadian member Duo started to plan a kit for a very interesting variable impedance current drive amp last year. It had received some favourable comments.
'Not heard his progress since then as he was setting up a website - perhaps he would be good to contact.
regards
Old 1st November 2011, 05:40 AM   #55
My experimental current-driven loudspeaker with motional feedback from a second voice coil worked rather nicely. Pity I didn't have a practical application for it.
Another way to get rid of the response peak around fundamental resonance is to just equalise it out with a filter (Linkwitz transform circuit or other type of filter with two zeroes and two poles). The problem with this is that the filter zeroes will never be exactly on the loudspeaker poles. As a result, you will get some small ringing that damps out slowly.
Tube line stage output impedance regal Tubes / Valves 28 21st July 2010 12:40 PM
3C24 in a SE output stage - output transformer impedance recommendation !!! aldovan Tubes / Valves 15 6th September 2008 10:18 AM
Tuning 604 Project - High Q and High Output Impedance? Seadweller Multi-Way 20 18th February 2008 07:49 PM
12AX7 gain stage output impedance Dave Z Tubes / Valves 3 3rd February 2008 05:29 PM
Balanced Zen Line Stage Output Impedance? AudioAngel Pass Labs 6 29th December 2006 07:38 PM
Page generated in 0.17376 seconds (47.43% PHP - 52.57% MySQL) with 11 queries
