#1961 |
Thanks Vitalιca
I have not done anything in particular I like to have friends. So simple. |
#1962 | |
#1963 |
If anyone can help me to furnish my BOM, please do so. Some of the components may not have a proper rating. For those who had finished and experienced, please comment on those ratings and make it easier for those who are going to work on this project.
For the 4.7pf caps on the main board, will 5p be as good? Thanks. BP |
#1964 |
What is the accuracy of the 5pF alternative? could it be +-1pF?
What is the required accuracy of the 4.7pF? |
#1965 |
Hi AndrewT,
Thanks for reply. Less say the spec from the vendor would be 10% (I will confirm with them) but the schematic never says anything about it. BP |
#1966 |
You will be very lucky to find a vendor that supplies 5pF +-10%, but there will be some.
The designer who specified 4.7pF probably also knew that @ that value most caps have a very wide tolerance range. |
#1967 |
^what do? buy a hundred of those caps and test on a meter for the closest match....
http://www.elab.ph/forum/index.php?topic=32688.0 |
#1968 |
#1969 |
diy newbie
why don't you just use 5pF???
" If you're going throu hell, keep going" |
#1970 |
Without reading through 197 pages of posts, could someone give me a brief rundown on this amp? Things I'd like to know:
1) Power output 2) Total cost (not incl. custom PCB) of parts 3) Recommended PSU or at least required input voltage 4) Performance compared to other DIY amps of similar price |
| anyone heard of these? | beauistheman | Multi-Way | 12 | 22nd September 2008 06:49 AM |
| Has anyone heard of the Pioneer SA-7300 amplifier made back in the 70's? | pkgum | Solid State | 8 | 11th April 2008 01:54 PM |
| ANA Audio Research APA 8 Power Amplifier. Heard of it? | Junior | Solid State | 0 | 1st August 2007 12:56 AM |
| Anyone ever heard of | Staticjeep | Music | 0 | 9th March 2006 02:15 AM |
| Anyone heard of Jam-Tech True Fidelity Amplifier? | tschanrm | Class D | 1 | 17th November 2005 01:10 PM |
