The Very Best Amplifier I Have Ever Heard!!!! - Page 156 - diyAudio
Old 14th March 2011, 03:23 PM   #1551
Originally Posted by jacco vermeulen View Post
It means, the Memisis was indeed a complete modular design (or should i say JOBby) ; universal gain stage module, exact same board for all of the larger models.
For a different model number : just pick a couple of different value resistors, number of power MOSFETs and the max Vds type, change of transformer and lytic caps.
Rest is standard.
Haute couture prices, with a prêt-à-porter production setup.
As the Memisis 8 demonstrates (even standard L-angles).
The standard L-angles makes storage easy.
File Type: jpg Goldmund factory in Neuchatel in 1994.jpg (16.7 KB, 1323 views)
Old 14th March 2011, 03:35 PM   #1552
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Oh, a contest.
My bad, 22222.462.7XXXX
It doesn't count how one deals with winning, but how to handle a loss (© DjT)
Old 14th March 2011, 06:37 PM   #1553
Pingrs is offline Pingrs  United Kingdom
Originally Posted by sng001 View Post
What is the type of capacitors on the bottom side of the PCB?
I think Jacco meant these (the lacquered version)
Brian.
Old 14th March 2011, 07:23 PM   #1554
Or..
[see top of the board, 10nF F250 +47pF F630, is 250V and 630V)
Old 14th March 2011, 07:25 PM   #1555
AndrewT is online now AndrewT  Scotland
It looks like it has been repaired.
Have the repairs been done competently?
Why were the repairs necessary?
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 14th March 2011, 08:20 PM   #1556
[QUOTE=jacco vermeulen;2503671]Or..QUOTE]
Whaddya know, I've found a few KP's amongst my stash of KS's. Thanks for that data, Jacco.
Brian.
Old 14th March 2011, 10:57 PM   #1557
What I meant was that the green 10 ohm resistor is a metal oxide type made by Roederstein. It is no loger in production. A replacement may be Vishay WK/WR.
Old 15th March 2011, 12:03 PM   #1558
nikosokey's Avatar
Default Golmund clone
Maybe this helps a bit.
Old 15th March 2011, 04:24 PM   #1559
Smiley 09's Avatar
snsg001
The blue caps are styroflex HF blockers, and the green res. are tubed metalloxide Withrom induct. free HiWatt 5% resistors.
CB
Old 15th March 2011, 06:45 PM   #1560
If so, then they're low capacitance value.
TO-3 mounting hole distance is 30mm, heart to heart.
The body of the bypass caps under the board is less than half that.
Not 15mm is 11mm, 11mm means low cap value (70Vdc rails)
See : http://www.komponenten.es.aau.dk/fil...elle/KS429.pdf
For a size reference : 45300pF/63V Polystyrene EMZ - 3.3uF/100V MKC Roederstein - 2.2uF/400V MKP Siemens
Has anyone heard of the Pioneer SA-7300 amplifier made back in the 70's? pkgum Solid State 17 14th November 2013 03:24 PM
anyone heard of these? beauistheman Multi-Way 12 22nd September 2008 07:49 AM
ANA Audio Research APA 8 Power Amplifier. Heard of it? Junior Solid State 0 1st August 2007 01:56 AM
Anyone ever heard of Staticjeep Music 0 9th March 2006 03:15 AM
Anyone heard of Jam-Tech True Fidelity Amplifier? tschanrm Class D 1 17th November 2005 02:10 PM
Copyright ©1999-2017 diyAudio
