The Very Best Amplifier I Have Ever Heard!!!! - Page 154 - diyAudio
Old 10th March 2011, 04:06 PM   #1531
Totally agree that R36 is 22 ohm. If it had been 0.22 ohm it would have been marked R22
or 0.22R. Thank you for this observation.
In simulation it will now handle 700 mW instead of 8W at full peak power into 8 ohms.
Old 10th March 2011, 04:45 PM   #1532
I am totally agree with NagysAudio
All the circuit he provide is correct as in real Goldmund 9.2
See attached
Moderator please delete this post if you find it not suitable to post public
Old 10th March 2011, 04:46 PM   #1533
hey the purpose of the output inductor resistor is to damp any ringing the coil may create at high frequencies. normal rule of thumb to make value at least twice the minimum value of the intended load. also make sure you use a device that does not exhibit any inductive of its own. I only use good old fashioned carbon 3-5watt and use it as a former for the inductor. wirewound or metal film is not really suitable for this. in fact the best results for high speed MOSFET dvices such as this work best with an all carbon resistor set. on numerous occasions I have come acroos people/DIYer's that change resistors in old equipment such as valve amps or tuners then wonder why they no longer function well or in the case of tuners at all. been watching this project thread with interest. understand as told to me prior post dunno the number its about "the attention to details" not too sure but think some or most of the resistors used on these amps are metal film. whereas I would not do this.
I have been doing reseach into Mosfet devices for audio for over 20 years. had a client who borrowed a design prototype from me years ago to compare to a musical fidelity and a Krell despite my asking him to return it some weeks later he only wanted to give me cash!!! not the unit so think building high quality audio is the norm for me. can someone clarify the used resistor set for this out of curiousity
Old 10th March 2011, 05:33 PM   #1534
ostripper's Avatar
I would be nice to know the bandwidth/resonant freq. of that L/R combo to see what it should be....
According to this... CalcTool: RLC or LC circuit calculator
the .22R/2uH has a limited bandwidth (17Khz). I use 10R/1.5-2UH in my amps (better BW - 800k) since the only purpose is to attenuate RF at the OP. (absorbed by speaker wire , etc)
So , by all reasoning ... .22R/2uH IS WRONG.
EDIT: unless ,in the case of the goldmund , the limited BW is there to accommodate RF created from WITHIN the amp.
OS
Wanderer - my travels.... Facebook - davyjones lockre -
Old 10th March 2011, 06:22 PM   #1535
Thank you arthur for your post. It answers a lot of questions and raises some more...
ostripper,
I have found this information about amplifier stability:
Elliott Sound Products - Audio Power Amplifier Design Guidelines
Old 10th March 2011, 06:59 PM   #1536
Krisfr is offline Krisfr  United States
Krisfr's Avatar
Speaking of CLR calculations, does anyone remember a Tektronix CIRCULAR Slide Rule like marked calculator for RCL circuits, does anyone have one that a photo pdf can be taken? It was a super good tool in its day... I loved it, I had 2 but they got lost in the life somewhere...
Never give a Systems Analyst a screwdriver or hammer
Old 10th March 2011, 09:59 PM   #1537
loek is offline loek  Netherlands
Default CRL
Maybe this can help?
The RF-Wallpaper / Die HF-Tapete
Old 11th March 2011, 10:49 AM   #1538
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Shame Nagy isn't around to see the power devices type/number used in the 1/2 priced, and 1/3d lower power model.
Didn't that GM brochure state that the 250W monaural used the same circuitry as the 9.2 ?
=> R95/R96 = 2k2 ( or 1k8/100V)
http://ouir.ch/generated/datenblaett..._Mimesis_9.pdf
It doesn't count how one deals with winning, but how to handle a loss (© DjT)
https://www.youtube.com/watch?v=FJEzEDMqXQQ
Old 11th March 2011, 12:24 PM   #1539
It's in here, somewhere ....
Slide Rules for sale on-line! Sphere's Circular Slide Rule Page
Old 11th March 2011, 12:53 PM   #1540
Cliff,
Kris just asked for images, to make one himself with a couple of CD's.
Like this :
http://classictek.org/images/stories...puter_1961.pdf
http://sliderulemuseum.com/HSRC/58111.jpg
http://cgi.ebay.com/VINTAGE-TEKTRONI...-/190509192793
(oh dear, i just enlisted in the old fart brigade)
Has anyone heard of the Pioneer SA-7300 amplifier made back in the 70's? pkgum Solid State 17 14th November 2013 02:24 PM
anyone heard of these? beauistheman Multi-Way 12 22nd September 2008 06:49 AM
ANA Audio Research APA 8 Power Amplifier. Heard of it? Junior Solid State 0 1st August 2007 12:56 AM
Anyone ever heard of Staticjeep Music 0 9th March 2006 02:15 AM
Anyone heard of Jam-Tech True Fidelity Amplifier? tschanrm Class D 1 17th November 2005 01:10 PM
Copyright ©1999-2017 diyAudio
