The Very Best Amplifier I Have Ever Heard!!!! - Page 110 - diyAudio
Old 1st November 2010, 10:20 PM   #1091
bsl is offline bsl  Hungary
hi alex!
would you be so kind as to post the last versions of the pcb-s? ( comlete docs - as you did it in the past )
thank you
Old 1st November 2010, 10:37 PM   #1092
Liliya is offline Liliya  Norway
Default Transformer and source resistors.
Ivodonchev, thank you.
Dropping 32/33 down to a lower value: A straightforward solution for me (and others).
But we are still talking of 50VAC to this point and not DC?
Alex, thanks to you too for listening about the source resistor. Your proposal to this on the underside of PCB will be easy to adapt for those who want/need it.
Eivind Stillingen
Old 1st November 2010, 10:50 PM   #1093
I am talking about 50VAC not DC too. Please look at the simulation
Old 1st November 2010, 10:54 PM   #1094
This is another valid solution
Old 1st November 2010, 10:59 PM   #1095
Default 2x50 VAC transformer for Goldmund.
Ivodonchev
According to the simultation you have done, a 80VDC capasitor for C31/C34 will be "safe" enough? 100 VDC not needed??
Eivind Stillingen
Old 1st November 2010, 11:15 PM   #1096
for 50vac transformer 80v capacitors is fine with sure
Old 1st November 2010, 11:30 PM   #1097
Here is simulation with 60VAC transformer, as you can see there are not difference in the power between two simulations. I think that the reason why Goldmund push mosfet's to the limit are primary sonic performance.
Best regards
Old 2nd November 2010, 05:06 AM   #1098
jam is offline jam  United States
jam's Avatar
Default We don't need no real engineers!
...............maybe we need to rename this thread, The Burning/Smoking Amp Thread.......
Old 2nd November 2010, 09:00 AM   #1099
dadod is offline dadod  Croatia
dadod's Avatar
Hi Alex,
Last PCB has an error as drain is pin no2 and sourse is connected to the MOFET case.
Old 2nd November 2010, 10:30 AM   #1100
Luke is offline Luke  New Zealand
Send a message via AIM to Luke
so then shouldnt the board have a place for source resistors?
If you give a man a fish he will eat for a day. But if you teach a man to fish he will buy an ugly hat. And if you talk about fish to a starving man then you are a consultant. Dilbert
Has anyone heard of the Pioneer SA-7300 amplifier made back in the 70's? pkgum Solid State 17 14th November 2013 02:24 PM
anyone heard of these? beauistheman Multi-Way 12 22nd September 2008 06:49 AM
ANA Audio Research APA 8 Power Amplifier. Heard of it? Junior Solid State 0 1st August 2007 12:56 AM
Anyone ever heard of Staticjeep Music 0 9th March 2006 02:15 AM
Anyone heard of Jam-Tech True Fidelity Amplifier? tschanrm Class D 1 17th November 2005 01:10 PM
Copyright 1999-2017 diyAudio
