The Very Best Amplifier I Have Ever Heard!!!!
Old 3rd November 2012, 08:48 AM   #2071
Jay is offline Jay  Indonesia
Banned
And the Electrocompaniet version from a russian site (I forgot right now, had internet issue at home), so a word document file...
Old 3rd November 2012, 09:04 AM   #2072
TANDBERGEREN is offline TANDBERGEREN  Norway
Just a bit of funfact:
Tandberg introduced the term DIM, wich in fact is excactly the same as TIM already in 1974.
Also I was lucky enough to have an professor as my teacher when I got my education as an electronics engineer. The very same professor wich trained people behind DOXA, SONOTRON (Later ADYTON), and other HIEND-manufacturers in Norway.
We named him "Professor Balthasar", as he looked just like him.
Sooner or later you end up with TANDBERG
Old 20th November 2012, 05:01 AM   #2073
Hi Jay.
Any diagrams for the powersupply?
It is mentioned in the article following the schematics for this amp,
"The amplifier is fed by symmetrical voltage 19V -44V and +/-26V to the power stage".
I am confused of the use of the term symmetrical voltage of 19V and -44V.
Clearly non-symmetrical as I can see it.
Anyone who can give some good input on this issue?
Old 20th November 2012, 09:08 AM   #2074
Banned
Originally Posted by TANDBERGEREN View Post
Hi Jay.
Hi, I don't have the power supply, sorry.
The original article in the Greek site I think was not accurate (τροφοδοτείται με συμμετρικές τάσεις +19V και -44V). The English translation found in the PDF is more accurate "The amplifier is fed by non symmetrical voltage 19V -44V and +/-26V to the power stage"
Here is the English translation (PDF)
http://sportsbil.com/other/ELECTROCOMPANIENT%20SCH.pdf
Here is in Greek
Electrocompaniet
Old 20th November 2012, 12:08 PM   #2075
msdin is offline msdin  United Kingdom
Default The original Electrocompaniet 25 watt class A amp
Hi Jay.
The supply voltages are not correct the feeds are symemetrical +/-27V for the input stage and +/- 33.8V for the output stage.
Old 21st November 2012, 01:20 PM   #2076
Better answer from Jay there msdin.
Checked with some others too, and they confirmed that the supply for the input stages are infact non-symmetrical.
Thanks Jay.
Old 8th December 2012, 11:19 PM   #2077
RS232 is offline RS232  United Kingdom
Hi all
Just to ask if the issue with the overheating in the VAS of this amp was sorted .
I'm inclined to build one for myself and I want to know if that issue was sorted.
Ric
Old 9th December 2012, 06:06 PM   #2078
tommy1000 is offline tommy1000  Denmark
The original GM design uses one clip-on heatsink for each VAS transistor.
Hope this helps.
Old 9th December 2012, 10:13 PM   #2079
Humm, yes I know that but in the last pictures the op but a huge heatsink on them apparently because the small one were not good enough.
I don't want to build something that is not reliable and safe.
Ric
Old 11th December 2012, 06:37 AM   #2080
nikosokey is offline nikosokey  Greece
nikosokey's Avatar
Default Golmund clone
Small heatsink for cold sites like Switzerland.
You must choose VAS stage 72 -75 degrees Celsius OR VAS stage 52-56 degrees Celsius.Temperature room 31 degrees Celsius. (Greece Summer edition )
The Very Best Amplifier I Have Ever Heard!!!!Hide this!Advertise here!
Has anyone heard of the Pioneer SA-7300 amplifier made back in the 70's? pkgum Solid State 17 14th November 2013 02:24 PM
anyone heard of these? beauistheman Multi-Way 12 22nd September 2008 06:49 AM
ANA Audio Research APA 8 Power Amplifier. Heard of it? Junior Solid State 0 1st August 2007 12:56 AM
Anyone ever heard of Staticjeep Music 0 9th March 2006 02:15 AM
Anyone heard of Jam-Tech True Fidelity Amplifier? tschanrm Class D 1 17th November 2005 01:10 PM
Copyright ©1999-2017 diyAudio
