The Very Best Amplifier I Have Ever Heard!!!!
Old 9th July 2012, 10:26 PM   #2051
smartx21 is offline smartx21  Brazil
Send a message via MSN to smartx21 The Very Best Amplifier I Have Ever Heard!!!!
Hey, Alex, did you make those cuts on the board, that have been discussed ealier on this thread or elsewhere? Or did you use your layout as is?
Max.
Old 10th July 2012, 06:44 AM   #2052
nikosokey is offline nikosokey  Greece
nikosokey's Avatar
Default Golmund clone
BUT this amp suffer on VAS stage 72 degrees Celsius with temperature room 31 degrees Celsius
Τhe next day i will show a new way to hold the transistors with clip to a larger cooler 52 degrees Celsius.
New way to hold the transistors with clip to a larger cooler 52 degrees Celsius.
Old 10th July 2012, 06:24 PM   #2053
Marko25 is offline Marko25  United Kingdom
That's some out of the box thinking that I like. Not the most pretty but very practical. Nice work.
Mark.
Old 10th July 2012, 10:52 PM   #2054
Unless I have missed it reading back through all of this, what is the pcb layout for the power supply?
Thanks,
Mark.
Old 19th July 2012, 02:25 AM   #2055
Dennis Isleta is offline Dennis Isleta
Hi Alex,
Good Day. Can you provide me schematics for this amp?
Old 28th October 2012, 11:50 PM   #2056
Mikewong is offline Mikewong  Italy
Could I use a pair of 500VA-220V/60V which I have with primary in parallel connection and the secondary in series to obtain +-84V DC in this project?
Old 29th October 2012, 10:29 AM   #2057
I have two toroid transformers with the same rating 500VA Primary 220vac/ Sec 60vac.
Would this connection safe or dangerous?
Old 29th October 2012, 10:35 AM   #2058
koldby is offline koldby  Denmark
koldby's Avatar
AndrewT,
I believe you misunderstand him.
He has TWO transformers , each with a 220V primary and wants to parrallel couple these two transformers and then series couple the secondaries from the two transformers.
As long as the phases is the same for the two secondaries , this is ok as far as I can see..
Koldby
What is Home Theatre without good sound?
Old 29th October 2012, 10:37 AM   #2059
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
yes, you can do that, just get your secondaries phased correctly....
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 29th October 2012, 11:41 AM   #2060
TonyTecson's Avatar
and where did mikewong ever said he that he had 110/120vac winidngs?
The Very Best Amplifier I Have Ever Heard!!!!Hide this!Advertise here!
Has anyone heard of the Pioneer SA-7300 amplifier made back in the 70's? pkgum Solid State 17 14th November 2013 03:24 PM
anyone heard of these? beauistheman Multi-Way 12 22nd September 2008 07:49 AM
ANA Audio Research APA 8 Power Amplifier. Heard of it? Junior Solid State 0 1st August 2007 01:56 AM
Anyone ever heard of Staticjeep Music 0 9th March 2006 03:15 AM
Anyone heard of Jam-Tech True Fidelity Amplifier? tschanrm Class D 1 17th November 2005 02:10 PM
Copyright ©1999-2017 diyAudio
