#31 | |
Banned
#32 |
The predominant noise in metal film resistors is "contact noise". Higher power ratings have lower contact noise for a given construction and current. A 2W metal film resistor will always have less noise than a 1/4W resistor from the same manufacturer. The contact noise is related to the geometry and the type of material. Better materials (Dale, for example) has less noise. Larger geometries (higher power ratings) also have less noise.
Secondarily, for any given device the thermal noise (Johnson noise) is proportional to temperature. Since a power resistor will be cooler, it will naturally have lower noise. Thermal noise is also proportional to resistance, which is why you never want a 1M resistor in your audio equipment. In general, for low noise, use the highest practical power rating, the lowest resistance, and keep currents to a minimum. Lately I've been using all Dale RN65 series. |
#33 |
I agree with jwb about the resistors. Unfortunately I cannot say that I am experienced with direct listening tests on many different resistor types. However it is clear to me that the 1W Vishay/Beyslag metalfilm that I mostly use, sounds really better than the typical small (1/4W) metalfilm.
Jos |
#34 | |
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference... |
#35 |
jwb
would you please post again details of schematic from first post I need the same steps and 20 K Input volume attenuator |
| YET another relay attenuator question | robmil | Solid State | 0 | 14th April 2008 05:44 AM |
| Relay Attenuator for tube amp | Vidi | Tubes / Valves | 9 | 11th December 2006 04:09 PM |
| relay volume attenuator for PASS pre | kiyull | Pass Labs | 4 | 26th February 2005 02:56 AM |
| relay based attenuator | squadra | Solid State | 21 | 1st December 2004 10:10 PM |
| Ladder relay attenuator or so? | Eccu | Solid State | 0 | 6th October 2003 11:00 AM |
| Page generated in 0.98548 seconds (7.39% PHP - 92.61% MySQL) with 11 queries |
