Old 27th September 2010, 07:23 AM   #1
mickb is offline mickb  England
Default Information on A940 Transistors
Hi Everyone, i've been asked to look at a cheap power amp that is broken, it has 8 No A940 Transistors which are all blown, the only information i can find for these shows them as PNP's.
I'm not to clever with electronics and would like to know if.
1) A class of amplifier is designed to have only PNP ouput transistors?
2) Does anyone know what A940 transistors could be other than PNP?
Thanks in advance for any information.
Old 27th September 2010, 09:02 AM   #2
alexcp is offline alexcp  United States
alexcp's Avatar
Your A940 must be the 2SA940 - 150V, 1.5A, 25W PNP transistors in TO-220 package. You can probably replace them with MJE15033. It is not common to see only PNP transistors in an amplifier, though.
Old 27th September 2010, 09:05 AM   #3
es44 is offline es44  Denmark
es44's Avatar
If You put a "2s" in front, it makes it a 2sa940. There are plenty of datasheets floating around when You ask Google.
It happens very very often, that the "prefix" is missing in schematics, honestly a bit confusing.
Best regards
Ebbe
Oops, Alexcp beat me to it
Old 27th September 2010, 09:31 PM   #4
Thanks to both of you for your replies, i've found the information about 2sa940's but what i cant understand is why this amp has only these transistors, the only other transistors in this amp are 3 c1815 and 2 a1015 per channel so if it is not common to see only pnp's in an amp could they be something else?.
Old 27th September 2010, 11:50 PM   #5
burbeck is offline burbeck  United Kingdom
hi Mick
your right it is very unusual, what is the make model of the amp?
regards
bob
Old 28th September 2010, 06:56 AM   #6
It says Liquid power 350 or something like that i haven't got it now.
Old 28th September 2010, 08:52 AM   #7
mjf is offline mjf  Austria
hello.
2sc1815.................2sa1015;
quasi (complementary) output stages use only one type,here pnp transistors....
they seem to be paralleled.........
i think this kind of amp you have does not deliver much output power.
if the seller acclaims 150w or something else - it is a bad choke.
greetings
Old 29th September 2010, 07:13 AM   #8
Thanks for your reply MJF so your saying that these are PNP's in the output stage?
the a1015's are the LTP but I don't know what the NPN 1815's do.
Old 29th September 2010, 07:25 AM   #9
Mooly's Avatar
As mentioned it will be a Quasi Complementary output... it's not uncommon.
The 2SC1815's will be one of the drivers and perhaps the VAS stage too.
When you power the amp up (if you attempt repair) then use a bulb tester in the mains supply to prevent damage if there should be a further fault causing the outputs to blow.
A simulation free zone. Design it, build it, test it.
Old 29th September 2010, 07:33 AM   #10
Mooly's Avatar
Here's an old Quasi design (lifted from an old thread of mine and drawn from memory).
This uses NPN devices as the outputs... but it's exactly the same for PNP... all the devices would be swapped, NPN for PNP etc and the supplies reversed.
i need a information about STK3152 Dj BASS AMP Parts 16 25th November 2011 08:51 PM
Some information please ivorthedj Multi-Way 2 18th June 2009 02:00 PM
Looking for information on old thread Coyote Tubes / Valves 0 13th May 2009 12:11 AM
Aleph information Jye Pass Labs 5 11th November 2004 01:14 AM
information silvano Pass Labs 2 7th September 2004 07:04 AM
Page generated in 0.09285 seconds (85.93% PHP - 14.07% MySQL) with 11 queries
