Old 23rd September 2010, 06:16 PM   #1
Default OpenLoop Gain and compensation
Hello world
I have an amp simulated and as real device, but I've some problems to simulate it's open loop gain. Is there anything out as info that can you recommend to read ?
Next problem is the compensation of the amp....At the moment there's only the capacitor across B-C of the VAS transistor...but there I must put >300pF in to get the amp stable at any load (in the real world). What's about a second order pole in the feedback ? In the simulation that works fine...but in real world ?????
Thanks.....
Designing audio electronics isn't a job, it's a mission
Old 23rd September 2010, 06:34 PM   #2
Federmann's Avatar
Send a message via ICQ to Federmann Send a message via Skype™ to Federmann
And the whole scheme?
Old 23rd September 2010, 06:45 PM   #3
as PDF:
http://www.ac-vogel.de/TheAmp_MK2/20...2010-06-30.pdf
and see pic
Old 23rd September 2010, 06:48 PM   #4
R22 and C5 are not placed (R-C across VAS)
C2 is 300pF (across VAS)
Old 23rd September 2010, 07:04 PM   #5
lineup is offline lineup  Sweden
lineup's Avatar
You have a supply rail filter D4 + R37 (10 Ohm)
I would rather put this before the VAS Constant current source.
So I should move them to the right of T7.
Current sources benefit from clean, constant voltage supply.
And this is what the filter D4 + R37 helps to give. su
lineup
Old 23rd September 2010, 07:06 PM   #6
Yes :-)
Error known and will be corrected in next "session" :-)
Old 23rd September 2010, 07:25 PM   #7
ostripper's Avatar
strange , this is almost the same as my "AX" which runs stable down to 22pF ??
edit , GET RID of the Darlington drivers !!! (tip 102/107) most likely they are the problem.
OS
Mongrel website , always current and updated :
http://67.248.209.21/D%3A/WEBSITE/
Old 23rd September 2010, 07:27 PM   #8
Ok... I've found something about testing OL gain in simulation (making the feedback R from output to some MOhms and replacing the feedback resistor to ground by 10F (!) ).
So I've Open Loop gain... the compensation in the simulation works fine (just where I want it) and I also get best results in simulation... but bad results in real world :-(
One prototype (breadboard) is performing well... the PCB type seems to be instable.... mhhhh... can the emitter resistors make an amplifier unstable ? There where other types on the breadboard than on the PCB....
Old 23rd September 2010, 07:29 PM   #9
OS
Why not darlingtons ? capacity too high ? They make unbelievable current gain
Old 23rd September 2010, 07:36 PM   #10
ostripper's Avatar
Oscillation city... standard MJE15032/33 drivers will give 2k hfe in a standard EF2 output stage and will allow the "blameless" to run on a single 33/47pF Cdom rock solid. I don't lie , i'm building my 10th pair of your amp "ax" below.
OS
Inverting FET openloop gainstage Onvinyl Solid State 28 19th October 2007 01:07 PM
op amp gain, woofer compensation? Joules Solid State 6 5th January 2007 05:23 PM
Low openloop gain amplifier lumanauw Solid State 33 7th February 2004 05:18 AM
Page generated in 0.10962 seconds (76.21% PHP - 23.79% MySQL) with 11 queries
