As a rookie, I try to keep the number of stages as low as possible. This leaded me to the idea to use mosfet's as driver stage, to minimise the influence of the load to my previous stages without using a triple EF.
But, it looks very difficult to find any info on this topic. Does anybody has some schematics as example to start from? The JC1 schematic would be great! I would like to use that driver stage behind a JFET (2SK389/2SJ109 input stage). The VAS stage with extra gain will not be a bad idea I think. See a previous thread which I posted before I started building my home (it's ready now). Fully complementary FET-in FET-out design But instead of mosfet output stage I bought Sanken 2sc2922/2sa1216 BJT's which I would like to use. The dual Jfet's and dual bjt's I have already laying around. Thanks Ben |
#2 |
This kind of topology, symetrical with cascoded differential VAS
is very good. I also used it as a first step to improve an older design. Just be careful to correctly compute the standing currents and the compensation scheme and it will work perfectly. |
#3 |
I've tried bjt>mosfet>bjt tripple darfetlington output stage and it worked well. Not as fast and stable as mosfet output, but linearity was fine.
#4 |
#5 |
I know John Curl used Mosfet's (2SK1530/2SJ201) as drivers in his JC1 (mentioned in this forum) and that accuphase uses also Mosfet's.
Still, 95% of all schematics I've seen have BJT's implemented as drivers. Can anyone help me to find out the advantages/disadvantages of using Mosfet's VS BJT's as drivers. Advantage of Fet's 1. No influence from load on output 2. Less predriver/driver stages needed in general 3. Faster than BJT's 4. ?? Disadvantage 1. Higher input capacitance 2. ?? Greetz Ben |
#6 |
Did it Himself
Hi, I have the perfect amp for you. I just made two PCBs for a friend last night as it happens, now that I have the design working stable and sounding good. I will upload schematic later.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#7 |
| Why not this pre-stage driver? | hahfran | Solid State | 0 | 28th August 2010 02:58 PM |
| Help with input stage driver for EL84 output stage | AudioGeek | Tubes / Valves | 2 | 20th March 2010 01:38 AM |
| Output stage biasing, with the driver stage | andrew_whitham | Tubes / Valves | 0 | 19th May 2007 11:14 AM |
| opamp driver stage | Acoustat | Solid State | 11 | 22nd February 2005 10:09 PM |
| driver stage | nonos | Tubes / Valves | 2 | 11th June 2004 06:54 AM |
| Page generated in 0.08874 seconds (74.51% PHP - 25.49% MySQL) with 11 queries |
