is this circuit is working?
how can i convert this sub amplifier to normal amplifier |
#2 |
'Subwoofer' amplifier in that context translates to 'lousy'.
In most contexts actually... |
#3 |
I have to agree with darkfenriz
And say that I have seen 100-reds of better amplifiers. Some points: A) Q5 and Q7 is the same(NPN). So called Quasi complementary. There is no need to make such a solution today. We have good True complementary NPN+PNP pairs. B) D1, D2, R9 and R10. They form a bias control for output stage. There is no reason not to use a proper Transistor for this. C) C4, R11 and R12. A so called Bootstrap. Bootstrapping is an old technique. This was probably because of lack complmentary VAS transistors. Better to use a proper current source. 2 transistors + 2 resistors. D) The input pair Q1, Q2 get their current from R3, R4. Just like in the Bootstrap case, we should use a proper current source to feed Q1.Q2. This will improve performance with several levels! It is not that amplifier will not work. It is that the quality of the work it can perform is bad. If we compare with even a basic amplifier like the Blameless. Here is the Blameless. You can find those details I mention. You have to mirror it upside down to compare ![]() We can find more reading at Douglas Self amplifier Institute The Amplifier Institute.
lineup |
#4 |
#5 |
hello.
to me it looks like a cheap old style schematic. c1,c3 are too tiny ,they cut off the bass...........c5 is very big........bias control is primitive...........and so on. there are better schematics ,simple and cheap,like p3(a) or so........ greetings |
#6 | |
G² |
#7 | ||
I have great confidence in Nelson Pass. It probably works. But I would not do that way. Probably not even Nelson today! The weak spot is the VAS in my opinion. The current in VAS is: Vsupply/(4.7k+4.7k) For 30 Volt we get ~3 mA in VAS. For 20 Volt we get ~2 mA in VAS. If I was to drive big MOSFET (HEXFET), I certainly would use more current than 2-3 mA. Not below 10 mA, for me. Which means I would use other transistor than 2N3904 for Q3. To hot up the gain we could even consider a 2 transistor darlington for VAS. But I think this is not necessary. It all boils downto how much global gain and feedback you want. And how much total harmonic distortion (THD) you think you can tolerate.
lineup |
#8 |
What?? Im running 2x35VDC and getting over 100W continous into 4 ohms.
#9 | |
G² |
#10 |
None of the small signal transistors actually have 70v between C and E.
Im running 2x35V just fine, no prollems at all. I'll leave it up to you to believe that or not. |
| 100watt Amplifier | emmi | Solid State | 4 | 31st August 2010 10:44 AM |
| 100watt guitar amplifier | shreya | Solid State | 4 | 15th August 2010 11:13 AM |
| 100Watt MOSFET Amplifier (Amos 100) | suds | Group Buys | 0 | 9th January 2009 07:12 AM |
| DIY Pass labs 100watt amplifier. | microwalsh8504 | Pass Labs | 12 | 6th February 2004 07:27 PM |
| 50-100watt amplifier schematics wanted | Jean | Solid State | 42 | 6th August 2002 08:12 AM |
| Page generated in 0.11932 seconds (80.56% PHP - 19.44% MySQL) with 11 queries |
