Does anyone have a list or spreadsheet of Power Transistors for POWER AMPLIFIERS?
Or is there a place on the web to find what are MATCHED pairs and what their ratings are? Like MJ15003 and MJ15004 MOSFETs too... Thanks |
#2 |
#3 |
The complementary is often stated in the Datasheet.
regards Andrew T. |
#4 |
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software. |
#5 |
IRF240 and IRFP9240???
Have you ever looked at those on a curve tracer? They are not even close. Sounds like something you must have read about in some magazine article or something. |
#6 | |
Feedback sorts out any differences. I use them in my amps and get great results. There are loads of amps arounbd using them, they are often pushed on here.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software. Last edited by nigelwright7557; 23rd September 2010 at 12:36 AM. |
#7 |
OK, then. I guess the answer to the original question is that it doesn't matter if the transistors are complementary because feedback will fix everything up.
#8 | |
The IRFP9240 was made to be a complement of the IRFP240. Clearly P channel is much more difficult to make and some compromises had to be made.
#9 |
Greg Erskine |
#10 | |
I actually use some of the most non-linear mosfets that could be used (cheap planer 'Q-fet' type switching FETs from Farichild), just out of curiosity to see how they could be made to work, but mostly because they have the same trans-conductance, which is the more important issue when using complementary source following mosfets. But with a very fast feedback/feedforward error amplified driver network those non-linear components do not make their way back to the 'global' loop. This is something the typical single GFB loop LIN topology, designed for BJT's, just won't do if one simply substitutes these mosfets in for the BJT's.
All the trouble I've ever been in started out as fun......
| Power transistor for class A amp | MrJimBeam | Parts | 3 | 9th January 2010 05:30 PM |
| capacitor brands & power transistor trouble on hk amp | mrlennon | Parts | 15 | 24th October 2005 03:37 PM |
| Your Favorite Signal, Driver & Power Transistor used in your Amp and Why? | John Biles | Solid State | 7 | 2nd August 2005 03:27 PM |
| Power amp transistor speeds? | AndrewT | Solid State | 7 | 23rd May 2005 07:13 PM |
| RCA 3626 power transistor from Crown amp | delapoer | Parts | 6 | 3rd June 2004 03:02 PM |
| Page generated in 0.09437 seconds (86.46% PHP - 13.54% MySQL) with 11 queries |
